98 EBCM power/upper board
I am facing problems (C1255 EBTCM internal malfunction) in my ABS module and decided to take it apart. I disassembled the EBCM from the BPMV, and dissoldered the upper(power board) from the gel-covered board.
I am trying to replace components in the upper board that may be bad (one of the capacitors is cracked and another one looks like suffering from heat damage), but I would like some help with the identification of the components if anyone with electronics background is able to.
Board is marked 217C174 P5 E00383B217C174 P4, and it is for a M type unit (Delco ABS-5/TCS/MSVA2 model 16257049 - without active handling, only traction control).
The components I was able to partially identify are:
2 relays (Bosch 0332019152), available ebay and other places
a power transistor - M 0035 745 - ** specs? - (CR2)
1 big/blue electrolytic capacitor (nichicon 820uF 25V ) (C4)
2 big/red varistor 1687 9748 - **specs? - manufacturer Harris (currently Littelfuse) - - 16mm disk - voltage suppression purpose (RV1 and RV2)
2 black diodes 40xx 3507xx - **specs? (CR4, CR3)
1 big/gray diode xx 7K C - **specs? (CR1) .
small yellow axial ceramic capacitors:
FC2 9744 - K5R 104K (0,1uF) (C1, C3, C5, C6, )
TV5 9746 - K5R 102K (0.001 uF) (C2, C9, C10, C11)
if anyone has corrections or better indications for the above numbers (especially those with - **specs?) it would be great as the numbers above do not identify the components and therefore we cannot find to buy.
Thank you.
big eletrolitic capacior 820uF 25V
K5R 102K
(2x) 1687 9748 / FC2 9744 / (2x) K5R 104K / TV5 9746 /
Cracked capacitor
TV5 9746
K5R 104K
FC2 9744
Probably cheaper to get a used Cadillac ebctm then a used Corvette ebtcm unit
https://www.corvetteforum.com/forums...tc-1243-a.html
