HID light problem
Old Apr 18, 2019 | 07:08 PM
tomz240's Avatar
tomz240
Default HID light problem
I just put in HID lights with projection assemblies. Everything on both sides is hooked up identical. Driver-side works passenger side won’t work. On the passenger side the bright light stays on all the time whether it’s on low beam or highbeam. No blown fuses I checked those. Anybody have a clue?
Old Apr 19, 2019 | 02:51 AM
Tsumi's Avatar
Tsumi
What HID assembly did you buy? If it is something with a high-4 harness, you swapped the low and high beams on your passenger side.
Old Apr 19, 2019 | 05:12 AM
tomz240's Avatar
tomz240
Bought from The Retro Fit Source. Plugs on high beam and low beam are different. They aren’t interchangeable.
Old Apr 19, 2019 | 11:06 AM
Tsumi's Avatar
Tsumi
Which harness did you get? Does the driver side high beams work properly?
Old Apr 19, 2019 | 06:48 PM
tomz240's Avatar
tomz240
I got it figured out. Thanks for your help.
Old Apr 20, 2019 | 10:59 AM
jrprich's Avatar
jrprich
Share what fixed your issue for others that may find the same issue.
Old Apr 20, 2019 | 11:03 AM
tomz240's Avatar
tomz240
Took it to car toys
To HID light problem
