Code P0113 intake air temp sensor
Old Apr 23, 2019 | 06:38 PM
DIABL0's Avatar
DIABL0
Default Code P0113 intake air temp sensor
Pulled a code: P0113 intake air temp sensor 1 circuit high input.
The part is cheap about 20 bucks. Is this an easy fix? Can I drive it while it’s bad?
I haven't done any research yet. Any good videos or write up?
thanks
Old Apr 23, 2019 | 07:00 PM
DIABL0's Avatar
DIABL0
I see it may not always be the sensor an could be the wiring. I have no way to test it.
Do do you think it’s a costly repair?
is the sensor located on the intake box near the Maf?
Old Apr 23, 2019 | 09:13 PM
Ed Ramberger's Avatar
Ed Ramberger
That's a 2 wire sensor. With a multimeter you should see 5V across the wires with the sensor out and it should throw something like an open/high code or something similar. That will verify the wiring - especially if you wiggle it and verify the sockets are not spread.
You can research and find resistance values for the sensor at different temps.
Old Apr 23, 2019 | 09:37 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Just as Mr. Ed had mentioned it is a simple 2 wire thermistor... 5 volt reference and signal ground..,don’t know if you are experiencing any driveability issues but for now if you have a voltmeter and a heat gun or blow dryer it’s fairly easy to check the sensor..,this video should help and I believe this is a 99’s IAT !!
Old Apr 24, 2019 | 05:44 PM
DIABL0's Avatar
DIABL0
I took it to my local garage i use all the time. They tested the IAT and came to realize I needed a new one and one of the wires was broken. So I got a new IAT sensor and they had to wire in a new pigtail. came to $280 labor and parts. It drives much better now. Price seemed a little high but I would not be able to do this work so it was worth it IMO.
Old Apr 24, 2019 | 08:02 PM
Ed Ramberger
Odd that there would be two failures - sure they didn't throw a sensor in, then see it still didn't work and found the wire?
Old Apr 25, 2019 | 10:27 AM
Gordy M's Avatar
Gordy M
I broke a wire on my sensor, bout a replacement sensor that had the wiring and splice it in. No problems in the last 10 years
To Code P0113 intake air temp sensor
