Engine position sensor
Old Apr 25, 2019 | 02:39 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Engine position sensor
My car just quit
2001 C5 mn6.
code is P0335, crank position sensor.
is it on the harmonic balancer area?
never had to change one.
is it just unscrew the old one and screw-on a new one with one connector?
Old Apr 25, 2019 | 02:47 PM
feeder82's Avatar
feeder82
Its by the starter. Exhaust will have to come off, and the starter
Old Apr 25, 2019 | 03:43 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Just hope it's not a wiring issue or you'll have to do it all over again !!
Old Apr 25, 2019 | 04:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ALL OF THE ABOVE are 100% spot on!
BC
Old Apr 25, 2019 | 06:21 PM
coupeguy2001
Default P0335
Thanks guys
i just did clutch last weekend with rear main seal.
wonder if plug came out or burned on exhaust.
It hasn’t been a week yet.
I will post my findings
Old Apr 25, 2019 | 09:03 PM
coupeguy2001
Default Crank sensor
Got it out.
sensor appears to be rubbing on something
(like the crank)
Half the end is shaved an 1/8”.
Last weekend, i changed block plate, rear main seal.
could it have been possible to move the crank trying to get the pilot bearing out?
the thrust bearing would have kept the crank from walking.
but that’s what it looks like.
also, the engine seemed to have more power this week, a lot more horses, kinda
Old Apr 25, 2019 | 09:11 PM
C5 Diag's Avatar
C5 Diag
The sensor would have been rubbing on the 24X reluctor wheel... that is how the crank sensor works !!
Old Apr 25, 2019 | 09:25 PM
coupeguy2001
Default Sensor
What about heavier clutch?
pushing harder and worn thrust bearing?
Old Apr 25, 2019 | 11:26 PM
coupeguy2001
Default Sensor
All back together
doesn’t run
Old Apr 26, 2019 | 12:33 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
After messing with the crank sensor /and or replacing it or doing major engine mods you must preform a "crank sensor relearn procedure" This will re set the crank sensor alignment It can be easily done at a shop that has a TECH 2 or someone that has either HP tuners or EFILIVE software
Old Apr 26, 2019 | 05:42 AM
C5 Diag's Avatar
C5 Diag
Originally Posted by coupeguy2001
All back together
doesn’t run
Did you replace the crank sensor ??...I don’t see how worn thrust bearing can shave an 1/8 of an inch off the sensor it that’s what happened??....the worn bearing (longitudinal movement) wouldn’t allow axial movement that would indeed shave off the end of the sensor off !!...do you have a picture of the old sensor ??
EDIT: BTW your crankshaft end play (2001) should be .0015-.0078"....I really don't think this is your problem and if you haven't replaced the sensor stay with OEM if you finally determine it is bad...and after checking the circuit...if you did have an 1/8 inch clearance between the end of the sensor and the reluctor wheel the sensor won't work...it is usually in the thousandths of an inch clearance !!...if you need help how to check the circuit electrically let me know !!...but you're a Part 135 guy...you should know this !!...LOL !!...only kidding !!
Old Apr 26, 2019 | 08:49 AM
coupeguy2001
Someone mentioned that the sensor has to touch the “wheel”. Seems to me it is a toothed wheel and therefore the sensor detects the segments as they go by.
It is basically a proximity sensor. We have them in aircraft to detect what the landing gear position is, and as a pickup for the engine RPM, and other things, they never touch the wheel, but are a few thousanths away from it.
the original sensor plastic was worn away to expose a piece of copper under the plastic
Old Apr 26, 2019 | 09:02 AM
C5 Diag's Avatar
C5 Diag
YES !!...exactly like a "prox sensor".....near/far...I am VERY familiar with these too...LOL !!...and yes, like I had mentioned they do have a very small clearance...I have changed other crank sensors (not on C-5's though) that have a "peel and stick" if you want to call it that on the end of the new sensor that gets rubbed away as the engine starts turning...that sets the correct distance from the wheel during installation. The PCM expects to see a 0-12 volt square wave....if it sees 3-12 volts...no good...if it sees 0-9 volts...no good !!....the blue trace is my 24X crank and the red is the 1X cam on my '01 !!
Old Apr 27, 2019 | 12:50 PM
coupeguy2001
Default Sensor
Ok,
took sensor back out.
looked fine.
put it back in.
sounds like sensor is hitting reluctor ring and sounds like it is running on 3 cylinders.
taking the new sensor box, and the old sensor to auto parts store.
going to look at another new sensor, and compare the new and old sensors to determine that somebody did not switch sensors into the right part number box.
getting hot here.
supposed to be 100 degrees.
high temps just slow me down
Old Apr 27, 2019 | 01:04 PM
C5 Diag's Avatar
C5 Diag
BEST to buy OEM when it comes to any sensor !!
Old Apr 27, 2019 | 01:53 PM
coupeguy2001
Default Sensor
New sensor is same length as old one.
not sure why it’s hitting.
but going to pull it apart again.
fortunately, learning curve is out of the way, and i can get it out in an hour.
wish i had a lift
Old Apr 30, 2019 | 11:33 AM
C5 Diag's Avatar
C5 Diag
Did you figure out what was going on with your Crank Sensor ????
To Engine position sensor
Old Apr 30, 2019 | 12:47 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
We talked on the phone. He had burnt wires on the connector. He fixed that and it runs but very rough. He still has contact between the sensor and reluctor wheel. I told him it should not make contact with the reluctor and there should be 0.003" - 0.005" between them. He has a data log device that he can see the crank sensor wave forms. He is going to check that out tonight. I bet the wave form is inconsistent causing the miss.
Old Apr 30, 2019 | 01:39 PM
C5 Diag's Avatar
C5 Diag
Hey Bill !!
Thanks for the update !!...burnt wires aren't good for anybody. I have no idea of why his new Crank Sensor (is it OEM ??) would be contacting the reluctor wheel. The gap is very important and the PCM will get confused and process the signal if it sees the amplitude either too high or too low. The amplitude limits are most likely proprietary information...I didn't know some of these data logging devices can log the CKP waveform...is it some kind of graphing meter ??....even if his CKP waveform is OK but still has a rough idle it's a good idea to do Cam-Crank correlation !!
Old May 8, 2019 | 09:13 PM
coupeguy2001
Default Crank position sensor
I have had an education.
i have had the car since 2004.
it had 22K miles on it when i got it.
it has always had little minor things, but never any problem that kept me from driving it.
two weeks ago, it quit, got it towed home, and replaced crank position sensor with one from Standard Motor Products.
put it back together, it ran like crap.
i figured someone returned a bad part, got another one .
ran the same.
I finally went to the Chevy dealer and talk to a diagnostician and he said it sounds to me like it’s your map sensor is no good so I replaced the map sensor and it made no change .
I talked to an engine builder and he said those Standard Motor Products sensors are crap throw it away and go buy a GM sensor .
So I finally went and bought a GM sensor and when I put it in and started it up it ran perfect .
The moral of the story is if you’re going to replace a sensor on your engine you need a GM sensor because it was designed to talk to your computer .
