Fuel gage issues
Old Apr 28, 2019 | 09:28 AM
aahrested's Avatar
aahrested
Default Fuel gage issues
During the process of an LS1 to LS3 swap in my 1998 C5 A4, I installed the commonly used Wix fuel filter with the return line built in. I plumbed the return into the factory return on the driver side tank. Once I got everything running, all seemed fine. During the shakedown run, I decided to top off the gas, even though the gauge indicated a half tank. It ended up taking 14.5 gallons, meaning that it was nearly empty. My gauge was always accurate (except for the occasional needle pinned to empty, which a can of Techtron cured) prior to this swap, and I was wondering if anyone else has had this problem. I did not touch the fuel sending unit, and can't figure out why the gauge is now that far off. Any help would be appreciated.
