Progress with sinking clutch pedal
I daily drove the car for a couple weeks, with no change in behavior, clutch pedal still sinking and even sticking to the floor. I checked the fluid again and after a couple weeks of daily driving, it was almost as dirty as before. So I began to do another Ranger method, I got to the 2nd or 3rd set of 30 reps and realized just how ridiculous this was. There was literally no change in fluid content after the 2nd set and all I was doing was adding unnecessary wear and tear to an already compromised 15 year old clutch/hydraulic system. At that point I decided that I would just do a basic drain and fill every couple weeks, as needed and let the natural pumping action of daily driving take care of the fluid exchange for me.
I did this over the course of a few months and while the fluid seemed to be taking a bit longer to get dirty in between changes and overall cleaner, the clutch sinking and sticking to the floor did not change, in fact, it seemed to be getting worse over time. So through more research, it seemed like removing the assist spring (though very controversial) was the next logical step. I removed the spring and although the pedal was no longer getting stuck to the floor and requiring me to get my toes underneath to lift it up, it was still sinking most of the way down during prolonged high rpms. So slight help, but again, not a fix to the root cause. I continued doing drain and fills for the next few months, while researching more.
The next cheap and easy supposed fix pointed me to removing the bell housing inspection covers, though little explanation was given beyond "it allowing the clutch dust to escape and not get introduced to the hydraulics, via the slave cylinder". So I decided to remove the covers during my next oil change. I changed my motor oil/filter, did another clutch fluid drain/fill and removed my inspection covers. To my surprise, this is the one that did it. There was a noticeable improvement almost right away. I have been dailying it for 7 months now and for the first time in a while or maybe even ever, I can finally run a gear to red line, push in the clutch, make a gear change and repeat.
I am not really sure on the mechanics here, but the engineer in me would really like to know, how of all things, was this the thing that fixed my sinking clutch pedal? Some of the possible theories that I can think of are:
1. Better ventilation promoting a cooler and cleaner clutch and hydraulic system.
2. Increased airflow may have blown off some debris on the slave or pressure plate that was causing issues.
3. The pressure plate springs were getting hot, reducing tension and are now cooler, increasing tension.
4. The fluid is cooler now so less vapor/air causing sinking.
5. The fluid is just cleaner now, promoting better hydraulic operation.
Anyways I would love to hear some opinions/theories/advice.
I am going to try to pull the intake manifold and do a full bleed sometime in the future. I am also going to rig up a puller spring (something like the Linginfelter kit) on the clutch pedal at some point, to try to keep the pedal at the top stop, to allow better natural bleeding of air bubbles like GM intended, but I am not putting the assist spring back on.
Also from what I have read, every subsequent model up from the C5, got bigger and better bell housing venting.
From what I have read, the vent openings on the C6z are fairly large and people port them out further with good success.
Pic showing the oem C6z bellhousing vents:
Also from what I have read, every subsequent model up from the C5, got bigger and better bell housing venting. From what I have read, the vent openings on the C6z are fairly large and people port them out further with good success.
Agreed, but there is also a reason why they are facing rearward.
Makes sense that the entire system will last/work better when kept cool and clean.
https://www.corvetteforum.com/forums...e-floor-2.html
"-Open front of the bell housing by removing the plastic panels
There are 2 black plastic panels that cover the front side of the bell housing. The driver side has a small 3” panel held in place by 1-10mm bolt. The passenger side panel surrounds where the starter engages the flywheel. Disconnect battery, remove the 2- 15mm bolts and push the starter forward enough to pull out plastic panel. Before you reinstall the starter you can benefit from this wide open space. Check out the next step, Compressed air.
Total time will be between 10min and 1hr depending on stock exhaust manifold or headers and adjoining piping and space restraints and if on a lift or on the ground.
I would imagine that the panels were put in there to keep things from getting into the bell housing but the irony could be what was meant to protect the clutch hurt the longevity of it. The Driver side is shielded by the oil filter and the starter on the passenger side. It is quite amazing the amount of air moved by the clutch at idle from the “exhaust” ports of the bell housing, imagine what it would be in CFM@155mph 7k rpm. Ever heard of Smokey Yunicks flywheel supercharger?
Opening the front side of the bell housing is a crucial part of keeping things cleaner and cooler within the clutch. By allowing the front side of the bell housing to ingest airflow we now have a cross flow of air coming in and out of the bell housing and the faster we go the more volume of air through, like a radiator. With greater volume of high velocity air the clutch debris is expelled much more quickly rather than staying in the bell housing longer like the stock stagnant closed-front-entry (or it doesn’t exit but through a tiny hole like earlier Fbodies and GTOs). On our C6Z we even “ported” the “exhaust” side of the bell housing to even more aid in getting the airflow out. Futhermore, after about 7K miles we again cleaned it there was very little debris in the clutch and bell housing area and the fluid was in great shape too.
We feel that this is conclusive that it does keep the clutch much cleaner and cooler. What happens to a radiator when you block its airflow?
One more thing to mention about the GTOs and Fbodies: It has been our experience that the Heat and the clutch debris can very quickly ruin your fun. A few years back we had an ‘05 80K mile GTO with about 390RWHP and boltons, stock clutch. The vehicle was at a road course event and as the vehicle heated up it would lose hydraulics and not even be able to execute a gear shift by the end of a lap. We would have to draw out the DIRTY fluid and replace it every lap. (It is unknown how large a role the heat played it is difficult to test independently. When both sides of the bell housing are open it seems that it is no longer an issue.) Now looking back upon those experiences I know we could have resolved or at least greatly extended the proper functioning of the clutch. Since GTOs and earlier Fbodies do not have “exhausts” on their bell housings I would like to machine a few passages in there and see what happens......Now we have done the aforementioned methods to said vehicles and it has helped rather significantly but they NEED is the “exhaust” side opened up. When you take a look at the bigger picture you can see that it needs both clean high speed air in and high speed air out, just like an engine. Having only one side of it is merely half the battle. "
