Help finding EGR and fueltank pressure sensor
Hi,
I have had som issues with starting my Corvette -98, but with a new and flashed PCM the car starts again. Now, some codes to take car of since the car also wnt into reduced engine power.
I have the follwoing codes:
1) P0405 EGR valve position sensor circuit low voltage
2) P0452 Fueltank pressure sensor circuit low voltage
Can anyone please help me to locate those sensors, but also provide a link on a wiring diagram for the car.
Also, wher can I buy those sensor?
// Anders
// Anders
Moderator, Tech Contributor
Received 2,145 Likes
Don't see a P0405 DTC...no EGR on the C5 !!...the FTP sensor is located behind the EVAP canister access cover after you remove the right rear "wheelhouse panel"...this is the wiring for my '
01 FTP sensor wiring..,a 5 volt ref, low ref (ground) and the signal wire !!...video in case you don't know how to check the circuit...very easy !!
Here is a drawing of the 2000 fuel system . It seems to me that the sensor is located on top of the LH tank (if I understand the drawing correct )
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The C5 LS1/LS6 does NOT have an EGR Valve or system. You do have an Air Injection Reactor (A.I.R.) system with an electric air pump that inject fresh air into the exhaust manifolds at cold start to help CAT Light OFF earlier but, that is nothing like an EGR valve or system.
How are you reading the DTCs?
Are you using the cars built in DTC reading routine that is accessed by using the Drivers Information Center buttons?
Don't know how a C5 would throw an EGR DTC. Doesn't make any sense. Is it a History DTC "H" or is it Current "C"
Can you clear it?
Bill
Can you clear it?
Bill
Hi, I have the P0405, EGR valve position sensor circuit low voltage code. I have cleared the memory several times, and it do pop up. I also check the codes through my Tech II, and same reply. So who is right? My car says I have it, and here you it doesnt... Would like to have this sorted out...
Cruise-In VI Veteran
You need to confirm what what type of vehicle and or LS1 engine flash was done to your PCM before trounlshoiting any systems...
Cheers,
Goose
Ok, so I took it another round in my head... And it might be so that it is the new PCM / flashing that causes me this code, since it came out of a Camro -99. I loaded the data from a Corvette -98 through HP tuner, but might need to perform some adjustment of the codes...
Anyway, I still dont believe that this is the issue why I have reduced engine power. I still belive that the codes and Reduced engine power comes from faulty / low signal from some sensor. Anyone experienced a similar thing that could guide me on the sensors & location?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Absolutely correct.. The NON Y body LS cars, Camaro, Pontiac, GM Truck ect, use the same PCM and they have EGR Systems. Who ever did your PCM programming didn't program out the EGR reporting for the Y body Corvette. You can find a shop with a TECH 2 and I think they can program out that DTC reporting or reflash it to your VIN and it will not report the non Y body stuff.
Ok, thanks... I have a Tech II, so I will have a look...
But that still doesn't explain why I have the reduced engine power message, and a engine that goes like a bad lawnmover:-) I belive that it might be a faulty sensor or so that causes the low voltage signal, and reduced engine power.
Anyone that could help me out on the location for this engines sensors, or other tips?
// A
// A
