Battery Dead
Old Jun 7, 2019 | 12:56 AM
vegasbadboy's Avatar
vegasbadboy
7th Gear
Default Battery Dead
Just had my battery charged early today. And it's dead already. Getting the clicking sound. Not sure what could drain it that fast.
Old Jun 7, 2019 | 05:28 AM
Grandpa1's Avatar
Grandpa1
Maybe a bad cell in the battery. It happens.
Old Jun 7, 2019 | 08:28 AM
DDaaryl's Avatar
DDaaryl
The battery needs to be tested with a load tester. Advance Auto and other suppliers will do it for free of you can buy a load tester at Harbor Freight and do it yourself. Even new batteries have been known to fail early.
Old Jun 7, 2019 | 09:14 AM
glbeauchamp's Avatar
glbeauchamp
It may not be drained. Did you check the connections at the battery posts? You may have a ground problem. That's the first thing I would do.
Old Jun 7, 2019 | 12:44 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
i had a battery drain over night. It turned out to be a PC board for the electric seats
Old Jun 7, 2019 | 03:19 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
This! I just replaced an Optima that was only 6 years old....(piece of mind really), and the positive terminal was just a bit loose.
Old Jun 7, 2019 | 08:14 PM
jim993's Avatar
jim993
If the battery tests good after a complete charge, I would start by pulling the two seat circuit breakers in the passenger kick panel fuse center. Then do a battery drain test, there are numerous descriptions for testing for battery drain if you search "battery drain" in the tech section.
Old Jun 8, 2019 | 03:43 AM
moserbe's Avatar
moserbe
How old is the battery?
Old Jun 8, 2019 | 11:01 PM
Moved to C5 Tech.
To Battery Dead
