Hot and cold air
Old Jun 11, 2019 | 10:12 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Hot and cold air
Hi,
I'm getting hot air out of the drivers's side vents and cold air out of the passenger's side vents whether it's on vent or AC, fresh air or recirculating. It's done this since I got my 99 coupe back from the shop who repaired the wiring last week. I had some fried wiring between the alternator and starter. The starter was also pretty toasty so he replaced the starter. He also ran new wiring from the alternator to the battery.
My question is this. Is it just a coincidence or is this problem something he could have done inadvertently? I did some research on the hot/cold subject here on the forum and it points to an actuator. Could it be something else? I don't want to rip out the entire dash just to find out that's not the problem.
Thanks,
Jay
Old Jun 11, 2019 | 10:15 PM
2quick98's Avatar
2quick98
Have you tried re setting the codes? Mine use to do this and I would just re-set the codes and all was well
Old Jun 11, 2019 | 11:35 PM
TinkersVet's Avatar
TinkersVet
Most of the time it is just low on Freon. When mine does the cold on pass and hot on driver a refresh on the a/c Freon takes care of it for the summer. As long as the air flow changes when you go from dash to defrost and bi level you actuators should be working. Check that first.
Old Jun 12, 2019 | 08:26 AM
jd911's Avatar
jd911
I was getting hot air out the drivers side and cold air out the passengers side as well. I was also getting a bit of hot air out the drivers side with the AC off. The problem started immediately after the GM garage replaced the oil pressure sending unit. Those symptoms plus a higher than normal idle led me to think they didn't get the vacuum line attached. Reconnecting the vacuum hose on the rear of the intake manifold fixed both problems. YMMV.
Jim
Old Jun 12, 2019 | 11:39 AM
knewblewkorvette
I did look at codes and had no current codes though had quite a few history codes. All were reset. Still have problem.
Old Jun 12, 2019 | 11:42 AM
knewblewkorvette
Okay, I'll try the defrost function.
It was just refilled with Freon last year. The passenger side blows really cold air, just the driver's side doesn't.
Old Jun 12, 2019 | 05:21 PM
knewblewkorvette
I tried the defrost and it works but get this, the outsides of the center defrost are cold while the middle of the center defrost is warm. This was with the AC on.
Old Feb 28, 2020 | 07:22 PM
Hoganryan40's Avatar
Hoganryan40
This usually means blend door issue or low on refrigerant or both.
Old Feb 28, 2020 | 07:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
blend door actuator, there are two, drivers side not too much fun, pass easier !!!
Old Feb 28, 2020 | 07:50 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
https://www.corvetteforum.com/forums...-actuator.html
Old Feb 29, 2020 | 12:03 AM
Life’s good C5's Avatar
Life’s good C5
I pulled my driver seat out, lower bolster panel for more room and was able replace the actuator about 45 minutes and issue was resolved.
Old Feb 29, 2020 | 10:46 AM
dleibman's Avatar
dleibman
x2 had the same problem and had it replaced. Still happens when it is cold out. I hust manually adjust temp settings as need when this happens.
Old Feb 29, 2020 | 10:52 AM
Moved to C5 Tech.
To Hot and cold air
