P0171 and p0174 codes appear around town
Old Jun 12, 2019 | 11:37 AM
thetimmann's Avatar
thetimmann
2nd Gear
Default P0171 and p0174 codes appear around town
Have had the same P0171 and p0174 codes appear on my 01 vette but mine seem to occur when running around town at low idle or after frequent stops and starts. Almost like clockwork. Something about low idle, especially in hotter temps about 90. Can reset them and will stay off. Have clean MAF sensor, replaced gas cap and cannot see any vacuum leaks at least that are obvious? Any suggestions?
Old Jun 12, 2019 | 11:49 AM
gimp's Avatar
gimp
Out of curiosity, do you see RPM fluttering up and down at hot idle without you touching the pedal? Especially as you come to a stop, maybe it dips low, bounces up, dips low, bounces up ...
I had an intermittent lean condition on bank 2 that was caused by a failing gas pedal - well, technically, the accelerator pedal position sensor on said gas pedal. It also caused weird bouncing in hot idle RPM, which was a MUCH more direct cause->effect than an occasional lean-on-bank-2 condition.
Old Jun 12, 2019 | 12:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You most likely have a vacuum leak somewhere between you MAF sensor and your TB... have you had the MAF bellows off before it started throwing those DTC's ??...it's NOT a gas cap...that's a completely different system !!...last year I found a vacuum leak at the PCV where the "condensation" metal band (pictured) exits the PCV hose...I removed mine and sealed with RTV....you can take some Brake Kleen and spray it around that area, the MAF bellows (may be torn)
and also around the brake booster too...also look at the purge valve plastic hose at either end (pictured) !!...see if the RPM changes when you spray the Brake Kleen...if you think it's the PCV you can remove and plug that vacuum line, clear the codes and see if they come back...if they don't that's where the leak is !!....ENGINE VACUUM IS HIGHEST AT IDLE...that is when a vacuum leak will be noticed as you have !!
Old Jun 12, 2019 | 10:45 PM
02torchred's Avatar
02torchred
+1 on the vacuum leak being the likely cause.
Another option is to look up how to make home-made smoke machines to smoke-out the problem area
Old Jun 13, 2019 | 09:18 AM
Robrote's Avatar
Robrote
I made my smoke machine out of a soldering iron and bike pump. Have used it countless times and works fantastic.
Old Jun 13, 2019 | 11:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% on the vacuum leak Excellent pictures C5 Diag!
Old Jun 13, 2019 | 07:47 PM
RB211's Avatar
RB211
Had the same issue. Ended up being 4 of the intake manifold bolts being loose. After tightening them to spec, the codes went away. Ended up removing the intake and replacing the 8 gaskets for my own peace of mind, but haven't seen the 0171 or 0174 codes since.
To P0171 and p0174 codes appear around town
