Dual Climate Control Problem
Old Jun 25, 2019 | 12:04 PM
tmirisola's Avatar
tmirisola
Default Dual Climate Control Problem
For my 1999 Base.
I have the Dual Climate Control system. The Drivers side temp control dial will only allow the temperate be adjusted up or down 1 degree per the digital display. If you fiddle with the dial, it will eventually go up or down another degree. I have no codes and the A/C or Heat work fine.
Any suggestions?
Thank You
Tom M
Old Jun 25, 2019 | 03:33 PM
Moved to C5 Tech.
Old Aug 28, 2019 | 06:57 PM
tmirisola's Avatar
tmirisola
Nobody ever experience this problem????
Old Aug 28, 2019 | 08:59 PM
Ed Ramberger's Avatar
Ed Ramberger
https://www.corvetteforum.com/forums...uses-this.html
Maybe this?
To Dual Climate Control Problem
