Warped Rotors Again!
Old Nov 8, 2002 | 10:20 AM
cscollis's Avatar
cscollis
Default Warped Rotors Again!
It was cool outside lower 60's and I did a hard break from 100. 1 hard break and the rotors warped again. Any suggestions about front rotors that dont warp would be appriecated.
Old Nov 8, 2002 | 11:07 AM
90 droptop's Avatar
90 droptop
Default Re: Warped Rotors Again! (cscollis)
Baer Eradispeeds, they work for me. :cheers:
Old Nov 8, 2002 | 11:08 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
For the street, Eradispeeds and stock pads are the way to go. :)
vetterdstr :cheers:
Old Nov 8, 2002 | 11:52 AM
Ranger's Avatar
Ranger
The usual cause of warped rotors is improperly torqued lug nuts.
Have any of your wheel ever been off the car? If so, were they hand torqued to the spec torque setting when they were reinstalled?
Most folks with warped rotors have had wheels installed or replaced by dealers (Chevy or tire service) using air-guns. The uneven and over-torquing is causative.
Ranger
Old Nov 8, 2002 | 05:16 PM
gmblack3's Avatar
gmblack3
Default Re: Warped Rotors Again! (Ranger)
Also make sure that you have bedded them in properly:
http://www.stoptech.com/whitepapers/...otors_myth.htm
the proper tourqe is 100ft-lbs.
Old Nov 8, 2002 | 07:57 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Which rotors were you using...crossdrilled...slotted..???? Mfg. by whom????
Sure like to know before I buy my new rotors...
let me know..
thanks...
:smash: :smash: :crazy: :crazy: :crazy: :smash: :smash:
Old Nov 8, 2002 | 08:00 PM
QUIKAG's Avatar
QUIKAG
That's kind of odd. I autocrossed, roadraced (over 8 hours of HOT lapping), drag raced, street raced (braking from over 150mph) and my first set of rotors never warped in 25,000 miles. I replaced the pads and rotors then because the rotors were showing signs of spider cracking. I think you need to evaluate your driving habits to see if you're doing something out of the ordinary to cause them to warp. :cheers:
Old Nov 8, 2002 | 08:03 PM
oldace84's Avatar
oldace84
Crying out loud....I'm in the wrong place...
So sad......
bye.... :jester
Old Nov 8, 2002 | 08:10 PM
Bandit1's Avatar
Bandit1
Default Re: Warped Rotors Again! (oldace84)
DBA cross drilled and slotted. :yesnod:
Old Nov 8, 2002 | 11:36 PM
Dave68's Avatar
Dave68
Default Re: Warped Rotors Again! (QUIKAG)
My car has 7700 miles on it and I feel pulsations from the brakes when coming to a gradual stop. I can't help but feel that something is inherently not right, especially since I've owned many other cars and not one of them have had the same problem. The pulsations didn't start until the car had 5000 miles on it, so I can't believe that it is a result of improper breakin or factory torque sequence.
Old Nov 9, 2002 | 02:05 AM
User 81424's Avatar
User 81424
I done hard brakeing from much higher speeds on the autobahn and never warped. A friend of mine warped his 4 times, each time was a panic stop from 150mph!
Old Nov 9, 2002 | 03:04 AM
MachOne's Avatar
MachOne
Dont feel bad, I am on my fifth set of rotors. And mine didn't warp, they cracked, usually in several spots and all the way through. They say you can take the car to the track, but abviously afternoons of road racing with PF 01 coumpound pads was too much.
Old Nov 9, 2002 | 10:22 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Re: Warped Rotors Again! (90 droptop)
Yep! What he said. :yesnod:
Tom
Old Nov 9, 2002 | 10:38 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: Warped Rotors Again! (TCW)
The warped rotor cenerio always pop's up. Very common among hard drivers. Thermal cycled rotors is the way to go. :yesnod:
To Warped Rotors Again!
