When I was tearing apart the dashboard to get to be left side blend door actuator I had to unplug and remove the Bose Amp. After I had completed the left side actuator I bolted the amp back up and plugged it in. I am now barely getting a sound out of my radio. Unplug the harness from the amp and partially slid the plug back in and while moving it from side to side I would get sporadic power to the amp and the speakers would work. Fully insert the plug and I get absolutely nothing other than the radio working without the amplifier. The two fuses that power the radio and the amplifier are both good. Swapped the amp relay with the rear defroster relay thinking the relay was bad. Side note both relays are identical. So anyway swap the relays still no power coming from the radio. I even went as far as replacing the amp plug with another pigtail. Cut wires from old and soldered to new, 1 wire one color at a time. The Bose amplifier still does not work. Any ideas?
And NO, I DO NOT want to swap over to an after-market radio or go with a double din set up. I'm happy with the Bose system and just want it to work.
Also....had a spare Bose Amp, tried it. Doing the same thing so it's not the amp.
I'll have to look later tonight, but I think I have a coupe signal processor.
Gary
Gary, I swapped the processor with a know functioning unit. No change.
BTW, Coupes are not interchangeable with Verts and FRC's . Verts and FRC's use a different style plug.
...I am now barely getting a sound out of my radio. Unplug the harness from the amp and partially slid the plug back in and while moving it from side to side I would get sporadic power to the amp and the speakers would work. Fully insert the plug and I get absolutely nothing other than the radio working without the amplifier. The two fuses that power the radio and the amplifier are both good. Swapped the amp relay with the rear defroster relay thinking the relay was bad... ...still no power coming from the radio. I even went as far as replacing the amp plug with another pigtail. Cut wires from old and soldered to new, 1 wire one color at a time. The Bose amplifier still does not work. Any ideas?...
I take it you are actually referring to the Bose Digital Signal Processor (DSP) Module.
This module receives the 4 main channels Pre-Amp Outputs from the headunit through connector C4 , applies a 2-way crossover filter to the signals, feeding the lows to the door-mounted powered subwoofers, while the mids and highs are further "conditioned" and then returned to the headunit's built-in 4-channel Amp inputs via connector C3.
In other words, if the DSP Module stops working there should be no sound from any speaker, including the subwoofers.
The DSP Module receives power from Fuse 24 through Pin A12, ground from the headunit through Pin B1 and the ON/OFF trigger from the headunit through Pin A8. Could you verify with a multimeter those 3 points?
The DSP Module receives power from Fuse 24 through Pin A12, ground from the headunit through Pin B1 and the ON/OFF trigger through Pin A8. Could you verify with a multimeter those 3 points?
Perhaps a wire was damaged while fixing the a/c.
The next couple of days I have some other work to get done. Once I get back to the car I'll check those points and get back with the results.
Yes, that's the Bose Digital Signal Processor (DSP) Module. It is not an amplifier. I described its functions above.
Tried sending you a PM but your mailbox is full.
Anyway, Question on this testing of leads you asked to do. Can I do it with the plug to the processor out or does it have to be plugged in and back probed ?
Lou
...Question on this testing of leads you asked to do. Can I do it with the plug to the processor out or does it have to be plugged in and back probed ?
Lou
Thanks for letting me know about my inbox. I need to do some housekeeping
Since this test basically involves battery power and ground you can do it unplugged first, and if everything is fine, then plugged and back-probed to make sure voltages don't drop under load.
It would certainly help if this IDIOT who's writing this
would have put FUSE 24 back into it's proper slot.
I checked voltage from pin A 12 to B 1 and had zero volts. Checked pin A8 to B1 and had 13.3v.
So I checked Fuse 24 and noticed is was missing. After looking over the list on the inside of the fuse box lid I noticed there is NO FUSE for #22 yet I had a 20 amp fuse in it's slot.......DUH.😝
Swapped fuse positions and guess what? 👍👍
