Air in brake lines
Old Jul 20, 2019 | 05:41 PM
redzg's Avatar
redzg
I'm with Mr. Curlee on this one, see if you can get any air out of the master cylinder fittings. How many miles on the car -- and more importantly, the master cylinder? I have also had more than one master cylinder go bad during a bleed process, when the pistons travel further into the cylinder than usual, and find a bit of corrosion on the cylinder wall. One locked up with the piston at the bottom of the bore...
Just saying that if all else fails, try a new master. $80 for AC Delco on Amazon
Old Jul 20, 2019 | 06:39 PM
tiojames's Avatar
tiojames
Thanks, I'm going to give Bill's suggestion a try tomorrow. Car has 22,000 on it and brake fluid changed every two years since new.
Air up here is really dry so usually no problems with brake fluid picking moisture.
Old Jul 20, 2019 | 07:31 PM
jim993's Avatar
jim993
Even though you did not work on the rear, just bleeding the front may not get all the air out. The FSM order of bleeding is:
R-R
L-F
L-R
R-F
I always use this order no matter where I work on the brake system and never have air issues.
This might be an opportune time to put on speed bleeders and use the FSM order of bleeding. Bleeding via speed bleeders is a fast, one man job.
Old Jul 21, 2019 | 10:00 AM
tiojames's Avatar
tiojames
R-R
L-F
L-R
R-F
See post #18.
Old Jul 21, 2019 | 11:31 AM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by tiojames
Lines are upgraded SS and you cannot pinch them off. I have bleed one quart of fluid thru all four corner twice and results are the same.
I have been working on vehicles for over 40 years and know how to bleed brakes w/o getting air in the lines back thru the bleeders.
You asked for help. The suggestion regarding clamping off the lines was to eliminate a failed caliper seal as well or anything that may have happened at the other corners - and to tell you if you blew out the master or got air in it. If you've been working on cars for 40 years, then I would assume you've seen a coincidence failure - so the suggestion was to assume nothing and determine where the failure is. SS lines obviously make this troubleshooting step moot. No one questioned your past experience or knowledge - we replied to your request for assistance. Hopefully you got air in the master and Bill's thoughts will help.
I am curious as to why you removed the calipers to push the pistons back though. That seems like an awful lot of complication for something unnecessary unless there was something else going on.
Old Jul 21, 2019 | 01:10 PM
tiojames's Avatar
tiojames
My father had a Ford agency from the early 50's and I grew up working on cars. I have never had a "coincidence failure" you speak of.
Yes, I have asked for help and Bill is the only one who has some sort of an answer. I doubt that there is air in the master cylinder because I never let it go below half full during the bleeding process. I am going to try the procedure later today.
As far as to why I removed the calipers-it is much easier to clean around the pistons, and install the new pads on the bench than it is to do so on the car.
I have had the calipers off a couple of times before so to me it is no big deal.
Old Jul 21, 2019 | 01:41 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
what you are not getting is did you get air in the system, and if it's in the EBCM it is hard to get out and that's why GM has the Auto bleed function in the Tech 2 !!!!!!!!!!!!!!!!!!!
Old Jul 21, 2019 | 02:16 PM
Ed Ramberger
Well I know plenty of people who did brakes and had a master fail or a caliper seal go on some older cars.
As a tech I cant tell you how many times we get “ever since”. I was once blamed for a horn being inop after doing brakes. I got in the car, held the horn on and operated the tilt wheel to demonstrate the broken wire.
Seems like you got lots of good advice here from people trying to help and now you’re taking offense to it.
Best of luck to you sir.
Old Jul 21, 2019 | 04:07 PM
tiojames's Avatar
tiojames
I realize there is air in the system, I also realize there is no way possible to get air in the EBCM system if you are only disconnecting the brake lines at the calipers.
I am aware of the auto bleed function.
You keep mentioning the EBCM, so advise me how air can get into that system if the brake lines are only disconnected at the calipers.
Old Jul 21, 2019 | 04:10 PM
tiojames's Avatar
tiojames
Not taking offense and am grateful for the input. However, except for Bill's theory no one has suggested anything I haven't all ready tried, except the EBCM thing.
Old Jul 21, 2019 | 05:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
when back together you didn't push down the brake pedal ????? thus inducing the air ?????
Old Jul 21, 2019 | 06:07 PM
Ed Ramberger
Great. No possibility you keyed the ignition on while the line was open was there? You can bleed antilock like normal brakes and not get air into them, but if the unit cycles with the lines open and air in them, it can get into the unit. If that's the case, you're going to need a tech ii as previously brought up. There is always the possibility the master is damaged internally as well.
Old Jul 21, 2019 | 07:16 PM
  #33
tiojames's Avatar
tiojames
You can not induce air into the ECBM from the calipers. How are you going to get air 5 to 12 feet back thru the brake lines to the ECBM?
The brake lines were not drained of fluid and any air that got into the lines at the calipers can not travel back to the ECBM when I tape the lines ends to prevent fluid loss.
Old Jul 21, 2019 | 07:41 PM
  #34
Pounder's Avatar
Pounder
1/4 mile/AutoX
what ever you say ??? your the one with issues not me, all three of our Vettes have perfect brakes and are bleed twice or more a year because we Auto X them (2 anyway) have used the Auto bleed function extensively on all 3 vettes !!!!
Old Jul 21, 2019 | 07:55 PM
  #35
Rob 02's Avatar
Rob 02
With the car up on jacks, one wheel could have been spinning thereby triggering ABS (traction control).
Old Jul 21, 2019 | 08:06 PM
  #36
tiojames's Avatar
tiojames
No Ed, the ignition was never on as the key stayed in the house.
Tjhanks for your posts, I have found out things i did not know from them, such as this one.
Old Jul 21, 2019 | 08:11 PM
  #37
tiojames's Avatar
tiojames
All four wheels came off at once and have not been put back on the car, and rotors have not been rotated.
As I posted above with Ed you have brought attention to things I did not know such as this one.
I have decided to let Lil Blue sit for a few days, then go thru the whole bleed procedure again.
My thanks to you, Ed, and all the rest of the posters.
