a/c blows lightly on high
Old Jul 21, 2019 | 09:43 AM
michael lake's Avatar
michael lake
2nd Gear
Default a/c blows lightly on high
my a/c fan blows hard and cools well but the air coming out of the vents is like the fan is on low....even on the highest setting. Seems like it should be much more air coming out of the vents at this fan setting?
Old Jul 21, 2019 | 10:20 AM
bc6152's Avatar
bc6152
Switch to interior recirc instead of outside air ventilation.
Old Jul 21, 2019 | 10:22 AM
michael lake
2nd Gear
Already tried that. No difference in volume of air
Old Jul 21, 2019 | 03:02 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Does it sound like it's blowing hard air but it's not coming out of the vents? If that's the case check and make sure it's not being diverted to the floor and defrost vents at the same time. If it is then you most likely have a vacuum leak someplace.
Old Jul 21, 2019 | 06:43 PM
Moved to C5 Tech.
Old Jul 22, 2019 | 10:03 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
First thing I'd be looking at is the blower motor resistor that sets the fan speeds. They do burn up over time. They're not real cheap as I recall. It's under the dash in the passengers foot well right beside the fan. Held in with 2 screws and roughly about 3-1/2" by 1-1/2" or so. Typically you can see if it's burned up because there will be traces on the board that are smoked. When mine died I could smell burnt electrical parts in the car.
Old Jul 22, 2019 | 03:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the blower motor changes speeds when you commant it to but the air delivery is weak, you most likely have an AIR BOX Damper door issue.
ALL the damper doors that control where the air comes out are vacuum operated. They use vacuum actuators to shift the damper doors. IF, you have a vacuum failure, NONE of the damper doors are in any specific position and you have air flowing out of ALL the dampers at the same time. You can check.
Feel the defrost, middle vents and the lower floor vents. If you select mid level,,, ALL the air should come out of the MID level if the actual damper are working.
The vacuum starts at the back of the intake manifold, runs down to the passengers fender well area and then goes to a reservoir and then goes to the different systems. That feed goes to a AIR BOX Vacuum control module where electric signals turn on solenoids to allow air to go to the proper dampers.
Bill
Old Jul 22, 2019 | 10:11 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I recently resolved a similar issue with mine. Having initially confirmed the vacuum lines were good... I later realized that the factory female connector behind the intake had cracked under role of its "ribs." I replaced it with a section of rubber and zip tied it like a sir. The vents now shift readily between settings, it blows hard and best of all it blows ice cold.
To a/c blows lightly on high
