C5 Overheating in AZ
Old Jul 28, 2019 | 11:25 PM
specialk70's Avatar
specialk70
Cruising
Default C5 Overheating in AZ
Hey fellow Vetters, I'm really stumped as to why my '01 Base model keeps running hot. After I sprung a leak in the radiator, I replaced the radiator with a stock replacement, along with the thermostat and new hoses. I filled the system with 1/2 gallon of 50/50 coolant, 2 gallons of distilled water and 8 oz.s of Water Wetter. I had used this product in the past and it dropped the coolant operating temps by at least 15 degrees. I have drove the car several times since and the reservoir remains full with no signs of leakage. Granted it's 110 degrees during the heat of the day but the car seems to slowly, gradually warm up the temp to 240. All replies will be appreciated.
Old Jul 28, 2019 | 11:28 PM
coletrickle35's Avatar
coletrickle35
Veteran: Marine Corps
C5 of Year Finalist (stock) 2019
St. Jude Donor '19-'20
I put two gallons of undiluted 100% Dex Cool in my radiator and a half a gallon of water in my reservoir after replacing my radiator .stays is nice and cool in hundred degree Heat.
Old Jul 29, 2019 | 10:32 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
did you do this ???
Fill the cooling system through the surge tank.
Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
Start the engine.
Allow the engine to idle for 1 minute.
Install surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
Shut off the engine.
Remove the surge tank cap.
Start the engine.
Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
Install the surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
Rinse away any excess coolant from the engine and the engine compartment.
Inspect the concentration of the engine coolant.
Old Jul 29, 2019 | 11:10 AM
specialk70's Avatar
specialk70
Cruising
Thanks for your reply. Like I’ve said before I used Water Wetter in my C3 before and it worked but maybe I do need to use coolant. Thanks
Old Jul 29, 2019 | 12:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get a hydrometer and measure the coolant percent. You need a solid 50/50 mixture or maybe a little more to keep the mixture from boiling. GM Changes the reservoir cap from the old 15 pound cap to a new and improved 18 pound cap. Highly recommend getting that cap if yours is the old 15 pound cap.
What do you consider RUNNING HOT? 200-230 is NOT out of the norm for a LS engine.
Our blocks can become air bound and cause cooling issues. Have you burped the block using the steam cross over fittings at the front of the heads? That is easy, free and it helps.
Bill
Old Jul 29, 2019 | 12:40 PM
specialk70's Avatar
specialk70
Cruising
Thanks for your reply. I drove the car yesterday in stop and go traffic, 110 degrees in the afternoon, and it warmed up to 240. Can you describe or send a link how to burp the block at the crossover? I’m not familiar with that...Thanks
Old Jul 29, 2019 | 01:07 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CALL ME PM Sent
Old Jul 29, 2019 | 01:51 PM
STRMLNE's Avatar
STRMLNE
Interested to see what works for you. Keep us updated.
Old Jul 29, 2019 | 01:56 PM
wrmiles's Avatar
wrmiles
Did you check fan operation
Both on low at 226, or 185 with A/C on
Both on high at 235
Old Jul 29, 2019 | 09:01 PM
specialk70's Avatar
specialk70
Cruising
Fans are cycling on, yes Thanks
Old Jul 29, 2019 | 09:06 PM
specialk70's Avatar
specialk70
Cruising
I am draining the Water Wetter product out in the morning and plan to follow your recommendations. Thanks
Old Jul 29, 2019 | 11:07 PM
BigGun's Avatar
BigGun
Is the air dam under the front of the car intact and not damaged? That can affect both low and high speed cooling.
Old Jul 30, 2019 | 12:57 AM
specialk70's Avatar
specialk70
Cruising
Good question and yes it is.
Old Jul 30, 2019 | 01:03 AM
WICKEDFRC's Avatar
WICKEDFRC
You must be up toward Phoenix. I am south of Tucson at 4,700 feet and zero issues. Even in Tucson the Vette will get warm but not that warm.
Let us know what works for you or if you will be moving to Alaska. Hahaha
Old Jul 30, 2019 | 01:19 AM
specialk70's Avatar
specialk70
Cruising
I am planning on dumping the Water Wetter and going back to 50/50 coolant tomorrow. Thanks
Old Jul 30, 2019 | 04:19 PM
STRMLNE's Avatar
STRMLNE
I’m in az as well. Just drove a pretty decent distance. It’s about 108° out. My temp didn’t go over 228°. All stock.
Old Jul 30, 2019 | 04:43 PM
specialk70's Avatar
specialk70
Cruising
I just changed back to 50/50 mix coolant and drove it for about 1/2 hour in city traffic and it finished at 235 degrees. Fans were running when I stopped at home idling. Burped coolant from the block at cross over and reservoir and system seem to be full. Guess I’m still stumped
To C5 Overheating in AZ
Old Jul 30, 2019 | 04:51 PM
gimp's Avatar
gimp
Blow out the radiator. Underneath the car, back to front, get the crud out of your fins. If you haven't done this in a while, you'll be shocked by how much crap comes out.
Old Jul 30, 2019 | 04:54 PM
specialk70's Avatar
specialk70
Cruising
Brand new radiator and cleaned the condenser coil while old radiator was out...Thanks
Old Jul 30, 2019 | 07:24 PM
gimp's Avatar
gimp
Specialk70: Do your temps climb to 235-240F during highway driving, street driving, or idling?
STRMLNE: Same question, since you're in the same area. You don't see above 228F. Highway, street, idle?
At 110F ambient, I would not be totally surprised at 240F hot idle, but I'd consider 240F too high if you're doing 75mph in 6th gear.
(Actually, are both of you running 6-speeds? The automatic will likely run hotter due to the trans cooler portion of the radiator, if I understand correctly.)
