oil on bolt by filter
Old Aug 14, 2019 | 01:15 PM
ace6th's Avatar
ace6th
Default oil on bolt by filter
I have a oil leak the bolt to the right above the oil filter was the highest point on the engine that i can find oil.
any suggestions on where my leak could be coming from?
could it be from the object right above the filter that has the 2 bolts?
any input would help, thanks in advance.
highest point of leak
Old Aug 14, 2019 | 01:22 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
re-torque oil pan bolts ???
Old Aug 14, 2019 | 01:27 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If that is all it is I wouldn't about it unless it may be dripping...DON'T freak out !!...spray some Brake Kleen around that area and wipe it down...see what comes back !!...in the Airline Industry our jet engines have more leaks than yours...LOL !!!
Old Aug 14, 2019 | 01:32 PM
ace6th's Avatar
ace6th
i have re-torqued them........this is why I'm stumped......can the oil temp sensor right above the filter leak oil?
thanks!
Old Aug 14, 2019 | 01:34 PM
ace6th's Avatar
ace6th
it is dripping, i have a pretty good leak
Old Aug 14, 2019 | 02:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WARNING! If you retorque the oil pan bolts to the factory spec, there is a very high possibility that you will STRIP OUT the bolts that screw into the block that go through the front and rear cover assembly. The problem is, the threads are oil contaminated and that causes the felt torque to be less than is actually being applied to the bolts.
Decrease the torque value to a value for oil lubricated threads for the size threads that are used for those fasteners. There are only four that really strip easily.
I agree,, Wipe down the entire area and run the engine and monitor for any oil that runs down from the back of the block. Most likely a leak from the Oil Pressure Sensor on the top of the engine block drivers side behind the intake manifold. You can see it with a mirror and a flashlight. Very common issue. Unless you have a puddle of oil under that car after sitting, just drive it like you stole it!
Old Aug 14, 2019 | 06:52 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
the housing/adapter for the oil temp sensor is a common leak spot.
You may also want to drop the inspection cover for the bellhousing to see if it has oil, if the leak continues after replacing the gasket.
Old Aug 15, 2019 | 08:25 AM
ace6th's Avatar
ace6th
what would you recommend to torque the pan gasket cover bolts to?
how many bolts in the bottom pan gasket? i can only see 5
thanks in advance
Old Aug 15, 2019 | 09:40 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://www.corvetteforum.com/forums...-sequence.html
Old Aug 15, 2019 | 09:47 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
https://www.corvetteforum.com/forums...que-specs.html
Old Aug 15, 2019 | 09:55 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some C5s have a ONE PIECE Oil Pan. (early C5s) and some have a TWO PIECE pan Late C5s. I don't know the exact date of the crossover. I know 2000-2004 have the two piece pans.
The part in the picture above is the upper oil pan section. The part that is resting on the ground would have the removable lower pan if it had that option.
NOTE, If you have a TWO PIECE PAN, removing the lower oil pan will NOT let you see any of the engines crank or internals to the engine. Just the pick up tube and some oil baffles.
https://www.google.com/search?q=C5+t...N5gsB1ryl3SWM:
https://www.google.com/search?q=C5+t...F_h6QOPq85E9M:
In this picture, you can see the long shanks of the TWO rear bolts that screw into the back of the block that strip easily!!!
Old Aug 15, 2019 | 11:07 AM
ace6th's Avatar
ace6th
thanks! can you tell me what the bolt, circled in yellow is?
can oil leak from here?
mine is missing on my 1999 c5.​​​​​​​
Old Aug 15, 2019 | 04:45 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
That is the lateral main cap bolt. If it is there a leak is unlikely and it should be there. A member did have leak when the bolt was missing.
https://www.corvetteforum.com/forums...ming-from.html
Old Aug 15, 2019 | 04:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Looks like you are missing more than one!
Old Aug 15, 2019 | 04:52 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Bill, it is the same picture that Armand Gagnon posted a year ago. So I don't believe that is his motor.
Old Aug 15, 2019 | 04:57 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
You should see a bolt head something like this. The pic does have a relocated oil pressure or temp sensor for a swap, best I could find on a quick search.
Old Jun 1, 2024 | 08:26 PM
VetteCop29's Avatar
VetteCop29
Default Very similar problem
My 2005 has the same oil smell with open air A/C intake open , the engine and manifold is spotless under the hood, but under the engine, garage mat catches quite a bit , center to rear of engine.
203,400 miles, runs great, I’ve had it since ‘09….
Pretty regular mechanic says around $800.,,does that sound right?
you can see the manifold is spotless….
To oil on bolt by filter
