help with bolt identification
Old Aug 15, 2019 | 11:03 AM
ace6th's Avatar
ace6th
Default help with bolt identification
i have a oil leak, can any one tell me the name of the bolt in the yellow circle?
can you leak oil from where this bolt is located?
mine is missing on my 1999 c5.
thanks in advance!
Old Aug 15, 2019 | 01:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Damn, Brother!! That's the rear bearing side bolt. Once the rear main bearing is properly torqued, that bolt is installed and torqued for added rear main bearing lower block support. Yes, its supposed to have a special bolt in that hole. Pull one of the OTHER bolts out and get another one just like it from the dealer.
You can see it installed in this picture LINK ATTACHED:
https://www.google.com/search?q=ls1+...POe3Tmdcde3ZM:
Do the other holes in the same area on the block have bolts in the holes????????????
Old Aug 15, 2019 | 01:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out this link and you can see where they fit into the actual main bearings. The LS engines have a DEEP block and that allows the the main bearing to have extra support in that area:
https://www.google.com/search?tbm=is...PlMEM5SNullUM:
Its called a side main cap bolt:
https://www.google.com/search?tbm=is...H6xKvgOyPFxr_M:
Old Aug 15, 2019 | 02:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please update us on the status of the other bolts and if you find the correct bolt. Its probably a standard GM Metric bolt but, I have never needed to do anything with all the engines that I have worked on.
Bill
Old Aug 15, 2019 | 08:15 PM
StingrayRebel's Avatar
StingrayRebel
oil pan bolts are very similar if not the same... why are yours missing??
Old Aug 16, 2019 | 01:02 PM
Robrote's Avatar
Robrote
I have heard that they are notorious for vibrating lose and falling out. I would put a little blue loctite on the new one.
Old Aug 18, 2019 | 08:22 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Looks like the one directly in front of the one mentioned, is also missing!
Old Aug 18, 2019 | 10:27 AM
StingrayRebel
maybe a rebuild and someone made a boo boo
Old Aug 18, 2019 | 11:05 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes, I saw that also,, Looks like he has more than one thats missing,, That's why I recommended that he check the others. My guess, someone's been in the engine before. Hope he gets back to us on an UP-DATE.
Bill
Old Aug 19, 2019 | 07:28 AM
dskinsler83's Avatar
dskinsler83
Someone has had that motor out and apart. The block is painted.
Old Aug 24, 2019 | 11:30 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OP,,, Did you ever sort this out?? What was the outcome????
Old Aug 24, 2019 | 12:01 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Hmmmmm, It's rusty. I don't think that's a Vette motor.
Looks like a crusty ole 5.3 maybe?
Old Aug 24, 2019 | 10:12 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep!!! The RUST confirms that its an iron block!!
Aluminum doesn't rust and the LS block isn't painted..
Bill
To help with bolt identification
