Which one?.....
Old Aug 17, 2019 | 06:07 PM
newblue1991's Avatar
newblue1991
Default Which one?.....
Which fuse is for the check engine light?, Thanks 2002 C-5
Old Aug 19, 2019 | 04:18 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Post your codes so we can see which one(s) are causing the check engine light
Old Aug 19, 2019 | 02:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is NO fuse for the CEL... Its a function of the IPC and PCM. The only way to make it go out is to fix the issue that is causing the PCM to be unhappy OR tear into the dash and remove the bulb. That will also cause you to FAIL EMISSIONS because the monitoring stations look for that light and fault.
Read the DTCs and report what pops up:
To Which one?.....
