Question about A/C Actuators
Vacuum leaks are what I'd address first. Get that all working. The path is from the back of the intake into the wiring harness, down below the battery and into the fender well on the passengers side. There's some stuff mounted to the A pillar and likely all of it is brittle and cracked. There's a reservoir for vacuum, a vacuum brake, and a Tee or two. From there it goes back under the battery through the bulkhead and to the vacuum divider. That stuff is all cheap and easy (relatively) and should eliminate most of your mechanical issues.
From there, the actuators are fairly easy, just a tad expensive. They're a colossal ripoff. GM should be ashamed of themselves for that.
Grab some vacuum hose, some emissions tubing (real small stuff) and get the vacuum fixed first though.
Both the same part.
Not sure I'd recommend used... Rock Auto ... . $100 each or so. 90 anyway.
Same goes for all that stuff mounted to the right side A pillar. All that stuff will have cracks and broken fittings. I can't imagine there's good vacuum all the way to the passengers compartment and THEN it is broke.
Just not buy'n it. I'd be more inclined to believe you're hearing something on the other side of the firewall. Maybe close by, but other side. If I'm wrong... then somebody had to have already replaced all the rest of the tubing and quit a few feet too early. To make that passage, I was able to cut a piece of that hard plastic tubing on a sharp angle, then push it through inside the wiring harness. You can pull out the old stuff first and give yourself a little more room inside the jacket. But it was pretty easy.
Even at 25% off I wouldn't bother with GM. They already have one chance to make a decent actuator, and they blew it.
When I did my C5 I ran a separate rubber hose from the back of the intake Down Under the battery. Reason being is I could not get the emissions tubing to travel inside the wiring harness and just wasn't worth it to deal with that. So that part of the trip was made outside the wiring harness wrap. From there though, I followed the factory path and The Passage through the firewall is really short so that's easy to do just pushing the emissions tubing through.
It's easy enough to check if you have a leak at any of those points because it's really just a straight shot. In a pinch you can just suck on the line and plug the other end and if air comes through you know something is wrong.
All the stuff under the dash to be perfectly honest is easy to look at without touching a single thing. That's all exposed. Once it comes through the firewall oh, you will see that black emissions tubing plain as day going all the way to that Junction block or whatever you want to call that distribution thing, you've got vacuum coming to that point. That block simply doesn't leak. And everything from there on it's just vacuum Dash parts and I hate to say they never fail but I've never heard of one failing. Okay? So I'm just playing the odds here and I'm saying that there's no reason for me to believe the vacuum leaks are inside. That would be the easiest place to fix. The rest of it is either behind the intake or in that damn fender well and those are not nearly as fun. If somebody fixed something, you would like to think they took the low-hanging fruit.
The VACUUM, ONLY controls the level dampers that direct the flow of the air through the HVAC Air Box. Defrost, upper vents, lower vents both upper and lower vents "BI LEVEL" and fresh air or recirculated air.
The vacuum line comes from the vacuum reservoir into the cabin through a wiring harness and goes to an electronic solenoid control valve. That valve is controlled by the HVAC Control Module. When you select DEFROST, the solenoid for the defrost opens and directs vacuum to a vacuum controlled damper servo piston and it moves a damper in the air box to allow air to flow out of the defrost vents and none of the other vents.
Each time that you select a mode of damper operation, the damper servo has to VENT and them vacuum is applied to a different servo dampener. IF, the hose for a specific servo is damaged, it will hiss when vacuum is applied. NOTE, All the servo hoses are a soft rubber hose (unlike the hard brittle vacuum line). The hiss can also come from a malfunction in the electronic solenoid control block that controls the vacuum routing for the air box.
EASY INSPECTION: Take the close out panel off for the passengers side and look at the servo control lines for the servos on that side of the air box.
Bill
Bill
This code means right actuator is out of range yet its the right side that is blowing cool air. When I go through the modes on the control the zones all change and the recirc changes to fresh air as normal.
The other day I noticed the AC was kind of neutral on the drivers side so I gave the system a little bump of 134 with no change. The next day when I tried the system I got only very hot air. Outside temp was 97 in NorCal.
After checking the codes I reset all of them and the AC worked again as described earlier. ANY IDEAs what to do about it? I'm considering replacing the receiver drier as I doubt it has ever been replaced. It can only help overall but it should not do anything for the difference in zone air temps.
Thanks for any help you might have.
Edit. After carefully reading the previous posts I will look closer at the vacuum system and replace the blend actuators.
I'm going from memory here... It's been several years...
As I recall, the drivers side you can get from underneath (if you've a contortionist). The passengers side I'm almost sure you have to remove the dash. I think I've heard folks talk about doing it with the dash just raised up some, but not completely out. In a Vert, (mine was a vert), I would almost say just take it out, it's easier. Maybe on a coupe the room to get the dash out is less and leaving it in is easier. On a vert, I think it's best to just remove it. I know that's how I did mine. I do remember laying in the footwell reaching up to do the driver's side though.
The aluminum structure is absolutely separate from the dash. It's not even part that holds it up. It's there for the airbag. Can be sharp too, watch that.
Cheers
