Fender replacement
Old Aug 22, 2019 | 08:25 PM
C5 for life's Avatar
C5 for life
Default Fender replacement
My drivers side fender just arrived. Thankfully. Never installed one. Wondering how hard it’s going to be to install. Ive been heavy industrial maintenance for years so I’m mechanically inclined. I’m confident I can do it. Just wondering what order of doing things is and what to expect and ensure I do.
regards
Old Aug 23, 2019 | 10:41 AM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
Very easy to do. Just unscrew one bolt at a time.
Old Aug 23, 2019 | 07:08 PM
C5 for life
Left my shop at 4. With ALL my tools! 🤦*♂️💩. Found a link earlier tools required were :
1/4 inch ratchet
7mm short socket
10mm deep socket
floor jack
jack stands
That’s all I remember lol. I’m an Industrial maintenance mechanic at a dry wall plant. 45 min one way or Home Depot 15 min 🧐
Old Aug 24, 2019 | 08:45 AM
Rx7Rob's Avatar
Rx7Rob
https://www.corvetteforum.com/forums...with-pics.html
Old Sep 8, 2019 | 01:27 AM
C5 for life
So I got it in and all finished up but the hole in the rocker panel is damaged 🤦*♂️ Which means it won’t hold tight to maintain the tight gap.
Old Sep 8, 2019 | 12:46 PM
burneyr's Avatar
burneyr
That hole/tab being broken is very common at the rear most edge of the fender.
I took the advice of many here with the same broken mounting hole and did this:
Fish the sheet metal tab out of the frame where the screw engages. Go buy a new one along with a slightly larger metal fender washer along with a rubber washer the same size. Use the rubber against the panel for grip, hold the fender for alignment, and tighten the screw.
Also, sometimes a small square of double sided body/molding tape helps in positioning. The new tab will accept a bit more torque than the older weathered one.
Did this fix three years ago and it's held perfectly.
To Fender replacement
