C5 engine hesitating
Old Aug 26, 2019 | 12:45 PM
Larry Vette's Avatar
Larry Vette
Cruising
Default C5 engine hesitating
Engine hesitating in third and fourth gear cruising at 1500 rpm
Old Aug 26, 2019 | 01:11 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you mean misfiring since you said.... "cruising at 1500 RPM" ??...just need some more info !!
Old Aug 26, 2019 | 01:27 PM
Larry Vette
Cruising
engine seems to struggle when cruising. As soon as I depress gas pedal the engine responds. Ease up on the gas and engine hesitates.
Old Aug 26, 2019 | 01:46 PM
Larry Vette
Cruising
I don’t believe it’s misfiring
Old Aug 26, 2019 | 01:47 PM
Larry Vette
Cruising
I’m not sure why my previous response was crossed out.
Old Aug 26, 2019 | 02:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When the hesitation happens, look at the IPC and see if the Check Engine Light (CEL) is on or flashing. You should also read and post the DTCs in the same ignition cycle as the issues is happening. Read them using the C5 built in DTC reading routine.
Please post all of your DTCs
Bill
Old Aug 26, 2019 | 07:24 PM
Larry Vette
Cruising
To C5 engine hesitating
