Thermostat opinion?
Old Oct 8, 2019 | 03:01 PM
Slammed337's Avatar
Slammed337
Default Thermostat opinion?
Thermostat needs replaced, debating the 160 or the 180.
Many thoughts?
2001 corvette
auto
heads, ms3 cam, intake l, exhaust car
Old Oct 8, 2019 | 03:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Where do you live (HOT OR COLD CLIMATE)??
How do you drive the car?
When do you drive the car SUMMER/ WINTER/ BOTH?
I personally would use the 180 deg stat and have the fans reprogrammed to come on sooner and run longer.
Do a complete coolant flush swap. Use distilled water and flush run fil flush/ run the engine/flush & fill till the water runs clean and refill with straight DEXCOOL till you get the correct dilution of water & Dexcool.
If you have not up-graded the coolant reservoir cap to the new 18 pound cap, recommend that you do.
Old Oct 8, 2019 | 03:23 PM
493lszosix's Avatar
493lszosix
Old Oct 8, 2019 | 04:13 PM
Slammed337's Avatar
Slammed337
Default Re
Was as leaning toward 180
i driver car pretty normal and occasionally aggressive
but mix of all seasons including winter if roads permit with no salt
Old Oct 8, 2019 | 04:26 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Oct 8, 2019 | 07:30 PM
Slammed337's Avatar
Slammed337
Default Re
Sounds like 180 it is
Old Oct 8, 2019 | 08:54 PM
6speedsteve's Avatar
6speedsteve
I am doing a full flush this winter & replacing the stat with a 180, I have HP Tuners but not sure what temps are recommended for that swap, I planned to just drop the temps by 10 for the fans, any insight on that.
Old Oct 8, 2019 | 11:11 PM
Rick369's Avatar
Rick369
What’s the advantage of upgrading to the 18 pound coolant reservoir cap?
Old Oct 8, 2019 | 11:50 PM
lionelhutz's Avatar
lionelhutz
Take it out on the highway with the new thermostat and see what temperature it stabilizes at. Then, set the fan off about 5*C higher, low fan on 5*C above off and high fan on 5*C above low fan on. Try it and see how you like it and then you can adjust from there. Might be able to take it down to 3-4*C steps and still work OK.
Old Oct 9, 2019 | 06:07 PM
turabo87's Avatar
turabo87
I have 160F and lowered fan on temps, at South Florida. No problems here.
Old Oct 9, 2019 | 09:48 PM
JWM's Avatar
JWM
I'm thinkin higher boiling point
Old Oct 11, 2019 | 02:59 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
We have a winner
http://www.tuneruniversity.com/blog/...-radiator-cap/
Old Oct 12, 2019 | 12:56 PM
y5e06's Avatar
y5e06
I ran a 160 on a C4 years ago, I found the heater never got hot enough on the coldest days, went back to 180 and it was much better. since then I use 180 or 185 t-stats whenever I'm changing them.
To Thermostat opinion?
