C5 FRC traction control
YOU ARE CONFUSING TERMS AND FUNCTIONS!
ABS = Antilock Breaking System: Prevents the braking system from locking up any of the tires during a braking event. You can not turn that function off.
Traction Control (TC): That function can be turned OFF using the button on the console. TC, If active (When you do a burnout and it is actively preventing the tires from spinning) will display a message in the DIC that says Traction Control Active and YES, that will limit burnouts.
If you turn it OFF, and if the engine has the required Torque and Horse Power, you will break traction (BURNOUT) When you depress the button on the on the console, do you see a Traction Control OFF message? Do you see the messages and do you hear the BEEP when the system changes from ON to OFF and back to ON?
Not all C5s can enter competitive mode You have the have the EBTCM/BPMV that supports Active Handling RPO JL-4 The feature appeared in 98 as an option and became standard in 2001.
QUESTION.. What Transmission do you have & What Differential gear ratio do you have?? My guess is an A4 and the 2:73 ratio differential. Not very conducive for spirited burnouts.
Please let us know what you have..Bill
It's also worth noting, unless you're doing a competitive drag race with a proper race tire there's never any practical reason to do a brake stand unless you like evaporating money into grey smoke....
same goes for aftermarket tire sizing this must be corrected in your tune
ALSO if you have aftermarket tires Tou must always retain the stock hieght differnece from back to front The rears being only 1 inch taller IF y ou alter too far away from this hgt differnece again your ABS and TC may false trigger
Has your car been tuned for the 3.73's
What are all your tire sizes ? measure the heights front and rear from the ground to the top of the tire ANY codes ?
