Tech 2 clone automated bleeding
Old Oct 10, 2019 | 07:34 PM
SoAlVette's Avatar
SoAlVette
Default Tech 2 clone automated bleeding
I have a new Tech 2 clone with GM software version 33.004. When I go to chassis special functions the menu does not list automated bleeding. It has automated test, which will check the valves, but
no automated bleeding feature. Am I missing something, do I need a newer version of software? Is there something on the CD's that came with it that adds this feature?
Mike
Old Oct 10, 2019 | 07:51 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
??????? https://www.corvetteforum.com/forums...h-2-bleed.html
Old Oct 10, 2019 | 08:10 PM
SoAlVette's Avatar
SoAlVette
It completes the automated test but gives no options after that. I have a 2000 with tcs/ah.
After running the automated test, the only option is exit.
I tried telling the tech 2 that my car was a 1999 model, and it did show the automated bleed option but would not connect.
I had my F45 programmed out by a tech 2 a couple of years ago, could that have anything to
do with this?
Old Oct 10, 2019 | 09:56 PM
ncali's Avatar
ncali
when you start that tech you have to give it the correct body style /year or it wont have all of the features. The cd's dont have that info on them
Old Oct 11, 2019 | 04:43 AM
SoAlVette's Avatar
SoAlVette
Is the automated bleeding feature not offered for the 2000 model?
Old Oct 11, 2019 | 09:07 AM
SoAlVette's Avatar
SoAlVette
Originally Posted by Pounder
You have a 1999, but listed it as a 2000 in the tech 2?
When I go through the menu this is what I get:
Opened Tech 2 main menu The screen shows:
• F0 Diagnostics
• F1 Service Programming System
• F2 View Captured Data
• F3 GM Performance Parts Diagnostic
• F4 Tool Options
Selected F0, Diagnostics
Selected Model year (2000)
Selected Passenger Car
Selected F2 Chassis
Selected Product Line (Y) “establishing communication” seen on screen
Screen displayed: CAUTION: “ABS Braking is not available when ABS/TCS lamps are illuminated” (Note: I had no Codes related to the ABS or TCS and no light on the dash)
Pressed the “continue” key selection. The right-most softkey was highlighted.
Screen Reads: “Chassis”
F0 ABS/TCS
F1 RTD
Selected F0, ABS/TCS
Screen Reads:
• F0 DTC
• F1 Data Display
• F2 Special Functions
• F3 Snapshot
• F4 ID information
Selected F2 Special Functions
Screen Reads: (Note, I think I should have a function key at this step for Automated Bleed, but it is not there)
• F0 Automated Test
• F1 Solenoid Test
• F2 TCS Test
• F4 TCS Switch Information
Selected F0 Automated Test
Screen showed ready for test and a softkey highlighted for CONTINUE.
Pressed CONTINUE softkey
ABS pump activated for a second or two.
Showed test complete and okay
Press exit to continue
Pressed exit and it goes back to the previous menu.
No automated bleed option.
Old Oct 11, 2019 | 09:43 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
you are using the Candi box right ???
Old Oct 11, 2019 | 09:47 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the write up in my thread was by someone else, I have used the Auto bleed many times, 99 coupe more than a couple times, 02 Z06 many times (Auto X it) 06 Z06 many times, (Auto X it) and my 06 Chevy truck !!!!!!
Old Oct 11, 2019 | 10:25 AM
SoAlVette's Avatar
SoAlVette
Not using the CANdi box, should I be? I thought it was for the later models.
Old Oct 11, 2019 | 10:56 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I'm sorry I don't pay attention to all the stuff I do (like it's a reflex) but I do believe you need to use the Candi box, won't hurt to try ??? (I always leave the Candi box hooked up )
Old Oct 11, 2019 | 11:07 AM
SoAlVette's Avatar
SoAlVette
I'll give it a try.
Old Oct 12, 2019 | 12:16 PM
SoAlVette's Avatar
SoAlVette
Candi made no difference. All other functions are available and work fine. The 2000 model is kind of unique, different than the 98/99 and before the 2001 upgrades. Obviously the automated bleeding feature is not available for the 2000. Bummer, that was my main reason for purchasing the tech 2
Old Oct 12, 2019 | 12:44 PM
oelarse's Avatar
oelarse
I think you have to choose 1997 or 1998 to get the Automated bleed to show up .
This is how my Tech2win screen looks like when I choose 97 or 98 .
If I choose 99 or 00 the F1:Automated Bleed does not show up on my Tech2win or my Tech2 clone .
I will try out the rest of the Automated Bleed prosedure using Tech2win later this winter when I replace the brake fluid .
Old Oct 12, 2019 | 02:37 PM
SoAlVette's Avatar
SoAlVette
I did get it to show up when selecting the 98/99. I'll try that again. I was looking in my shop manual and it makes no reference to the tech 2 in the brake bleeding section
Old Oct 12, 2019 | 02:44 PM
SoAlVette's Avatar
SoAlVette
Oh man, that's it. Thank you so much. It works using the 1998 settings.
Does not like the 1999 or 2000
Old Oct 12, 2019 | 03:13 PM
oelarse's Avatar
oelarse
Very good it worked out for you.
I have only done the two initial screen shown above but will try to carry out the whole Automated bleed procedure when my wheels are off later .
Maybe do some screen dumps of the different Tech2win screens and post it here at CF
Old Oct 12, 2019 | 03:58 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
funny mine is a 99 and have no issue using the Auto bleed ???????
Old Oct 12, 2019 | 05:29 PM
SoAlVette's Avatar
SoAlVette
I know, does not make much sense, but I'll take it
Old Oct 13, 2019 | 09:32 AM
SoAlVette's Avatar
SoAlVette
Just another of the many great tips from the Corvette forum. I would have never figured this out without help from the people on this site
To Tech 2 clone automated bleeding
