Fuse Box in engine compartment beeping?
Old Oct 28, 2019 | 01:29 PM
Bmiller1877's Avatar
Bmiller1877
Navigator
Default Fuse Box in engine compartment beeping?
Hello, I have a 99 Corvette and I'm a newer Vette owner. When start my car and shortly after there is a beeping from the fuse box in engine compartment. Just wondering if anyone knew what that meant or is it Normal? Don't recall hearing till lately and have had the car 6 months.
Thanks Brian
Old Oct 28, 2019 | 04:27 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
sounds like it could be a bad relay ??????
Old Oct 29, 2019 | 08:06 AM
runner140*'s Avatar
runner140*
Go to Harbor Freight and buy a cheap stethoscope (under $5.00) and figure out which one it is. I've got so much use out of mine....
Old Oct 29, 2019 | 08:29 AM
oharal's Avatar
oharal
Relays don't beep.
Old Oct 29, 2019 | 12:01 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by oharal
Relays don't beep.
OP 's interpretation ??? they sure can buzz ????
Old Oct 29, 2019 | 12:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,, there's NOTHING inside the fuse box that is suppose to make any noises.
You most likely have a bad/weak relay that making noises. Put a long screwdriver to your ear and on each relay. That will help you pin point the bad relay. Most of the autopart stores sell the relays.
Old Oct 29, 2019 | 12:10 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On another note,,,,,, You could very well have low voltage to the relays due to a defective IGNITION SWITCH!! If it were ME, I would check the relay COIL operating voltage "ESPECIALLY" if it ignition switch supplied to turn ON.
To Fuse Box in engine compartment beeping?
