Lean in on the windows ???
Old Oct 29, 2019 | 07:50 AM
ALLEN007's Avatar
ALLEN007
Default Lean in on the windows ???
I have seen this term on the forum. Where my drivers window meets the seal there is plenty of air sound while driving and you can see just a bit of the outside their as well. Not sure at all what "lean in" is. But is this something that would fix this? Thanks!!!
Old Oct 29, 2019 | 08:28 AM
oharal's Avatar
oharal
Post a pic so we can see. My weatherstrip is shrunk enough that the bottom 1 or 2 inches at the back of my driver window won't seal but I've adjusted the window to fit well and seal.
Old Oct 29, 2019 | 08:32 AM
wscott62893's Avatar
wscott62893
The term "lean in" is referring to the adjustability of the window regulator/track to increase/decrease how much the top of the window "leans in" towards the center of the car. Which impacts how it seals so yes, it could potentially solve your issue (assuming the seal doesn't need replaced). In order to make this adjustment, you need to remove the interior door panel. At the base of the window track there is an adjustable screw that angles the regulator/track assembly in the door accordingly. There are a few good write-ups out there on how to make the adjustment if you do some Googling.
Old Oct 29, 2019 | 08:49 AM
ALLEN007's Avatar
ALLEN007
oharal: Don't believe a photo would show it.
wscott62893: Thanks. When it quits raining in a couple days I'll take the cover off and give that a try.
Old Oct 29, 2019 | 08:51 AM
oharal's Avatar
oharal
Ok if that's the case an easy way to test the seal is to use a strip of paper. Close a strip of paper in the window and drag it around. If it slides relatively easily it's not right enough. If that's the case around the top edge, leaning in should help a lot. The adjustment takes some trial and error but isn't difficult.
Old Oct 29, 2019 | 08:53 AM
ALLEN007's Avatar
ALLEN007
Great idea. Thanks
Old Oct 29, 2019 | 10:37 AM
killian96ss's Avatar
killian96ss
Just to clarify the info above, there are 2 adjustment screws for tip in/out (front & rear) as well as 2 adjustment screws (front & rear) for height. You also don't need to completely remove the door panels to make the tip in/out adjustment, just pop out all the panel retainers and leave the panel hanging by the top. I also used a sheet of paper to help determine the necessary pressure between the glass and the seal. Since you can adjust both front and rear tip in/out it might take some trial and error.
Steve
Old Oct 29, 2019 | 11:02 AM
oharal's Avatar
oharal
Steve
A word of caution on this, the front and rear window tracks need to be adjusted in tandem to be parallel to each other. If they are not parallel the track will try to twist the window and since it's glass it isn't going to bend so it will bind up the sliders and unnecessarily load up the motor and slow the window down.
Old Oct 29, 2019 | 11:12 AM
killian96ss
Yep, this is why I wanted the OP and anyone else to know there are 2 adjusters. If you went in and only cranked on one you are definitely going to twist the whole assembly. Turning each adjuster the same amount is best approach unless someone else has previously adjusted them wrong.
Steve
Old Oct 29, 2019 | 11:25 AM
oharal's Avatar
oharal
The front adjustment doesn't have "turns" like the rear it's just a nut you loosen and you slide the bottom of the adjuster through a slot in the bottom of the door.
Old Oct 29, 2019 | 07:09 PM
ALLEN007's Avatar
ALLEN007
Thanks everyone for the info. I appreciate it!
Old Oct 29, 2019 | 11:02 PM
C5Rad's Avatar
C5Rad
Cruising
https://www.corvetteforum.com/forums...adjustment.doc
Old Oct 30, 2019 | 06:31 PM
_zebra's Avatar
_zebra
and don't over-tighten it, either. that's a good way to have it eventually dig a hole into your weather strip.
Old Nov 11, 2019 | 06:01 AM
ALLEN007's Avatar
ALLEN007
Well, I followed the directions in the above post attachment. I adjusted it 4 or 5 times with no change to the window. Should I just keep on adjusting it until it either works or will adjust no more?
Old Nov 12, 2019 | 11:59 AM
killian96ss
How much did you turn the tip in/out adjuster? Maybe you are turning the wrong way, moving the window out instead of in?
Steve
Old Nov 12, 2019 | 03:48 PM
ALLEN007's Avatar
ALLEN007
Steve
I followed the instructions given in an above post. Loosen the nut in the front (underneath the door). Then loosen the jam nut on the adjuster. Then turned the adjusting screw counter clockwise. I probably ended up turning it a total of 3 or 4 complete turns. Didn't seem like it did anything one way or the other. We had our first rain today since I got it and it does leak a bit on that side.
Old Nov 12, 2019 | 05:22 PM
killian96ss
.04 per turn isn't much so maybe you just need just need to keep adjusting counter clockwise until you see a difference.
Steve
Old Nov 13, 2019 | 05:55 AM
ALLEN007's Avatar
ALLEN007
Steve
Will do.
To Lean in on the windows ???
