12 Disc CD Changer
Old Nov 20, 2019 | 02:28 PM
jcblade's Avatar
jcblade
Default 12 Disc CD Changer
2002 Auto. Recently had some work done (new LS2). Everything worked fine before. The radio works fine and I can go from AM to FM with no problem. My problem is when I depress the CD button nothing is happening. It will stay on whatever station is playing. I checked the CD Changer in the trunck and it has power and seems to work fine. I also inserted a CD in the dashboard and it played. Seems like the CD AUX button is not working. Any ideas?
Old Nov 20, 2019 | 05:55 PM
Chillo32's Avatar
Chillo32
When you say “new ls2” you’re saying that you’re motor was replaced?
Old Nov 20, 2019 | 06:28 PM
jcblade's Avatar
jcblade
Yes, I threw a rod in the original LS1 and replaced it with a new LS2 block. I didn't do the work. If I remember correctly,. there is a kit when converting from the LS1 to LS2
Old Nov 20, 2019 | 06:39 PM
newblue1991's Avatar
newblue1991
Worth a try, I had a 97 caddy seville with a 12 disc c.d. player,whenever it acted up I simply pulled the power supply cord on the unit for a minute, it corrected any
problems.
Old Nov 21, 2019 | 01:14 PM
OregonDan's Avatar
OregonDan
Does your readout say "Err"? Have you checked that the CD's in the changer are in 'up side down'? Is the changer door closed, tightly?
Old Nov 21, 2019 | 02:26 PM
Chillo32's Avatar
Chillo32
Yeah. Most likely the cd is upside down.
Old Nov 21, 2019 | 02:30 PM
jcblade's Avatar
jcblade
No error message on dashboard. CD are in correctly. I opened and shut the door to make sure it was closed. Very weird. Before when I pressed the CD/AUX button on the radio it worked fine. It seems like the button itself is not working.
Old Nov 21, 2019 | 02:34 PM
Chillo32's Avatar
Chillo32
Could be so many issues especially since you did a motor swap. A lot of electrical stuff happening there
Old Nov 21, 2019 | 02:37 PM
jcblade's Avatar
jcblade
I was thinking the same thing. Thanks for your help anyway. If I get it resolved, I'll post back.
Old Nov 22, 2019 | 08:19 AM
oilyfishhead's Avatar
oilyfishhead
Check for 12V on the orange wire.
To 12 Disc CD Changer
