Best offset?
Old Nov 16, 2002 | 03:26 PM
gojo's Avatar
gojo
Default Best offset?
Which offset is recommended for the ZR1 17x11 wheels, 36 or 50, on a C5.
Old Nov 16, 2002 | 07:57 PM
gojo's Avatar
gojo
Default Re: Best offset? (jfpilla)
I thought this was an easy one for ya'll. :crazy:
Old Nov 17, 2002 | 11:38 AM
gojo's Avatar
gojo
Maybe I need to ask another way. If I use 335/35/17 drag radials, ZR1 17x11 wheels, with 50mm offset will they fit better than 36mm?
Old Nov 17, 2002 | 11:00 PM
gojo's Avatar
gojo
???????????????????????????????????????? ???????????????????? :sleep:
Old Nov 17, 2002 | 11:41 PM
Bill Dearborn's Avatar
Bill Dearborn
Get the Grand Sport wheel offset. Not sure which one it is but it sticks out less than the ZR1 offset wheel. The GS wheel will stick out beyond the fender about a half inch.
Bill
Old Nov 17, 2002 | 11:51 PM
0-60N4's Avatar
0-60N4
I may be really wrong on this, but I thought that the 17x9.5 was like 56 and the 17x8.5 was 52. Again, I reserve the right to be wrong on this.
This information is from me looking into Z06 Chromies from Xtreme on the exchange program. I believe the 18x10.5 is 56 offset as well. Best I can do.
Old Nov 17, 2002 | 11:59 PM
gojo's Avatar
gojo
Default Re: Best offset? (Bill Dearborn)
That helps. You can get the ZR1's 17x11 with GS offset 50mm. Thanks
"ZR1 style wheel with the 50mm GS offset".
[Modified by jfpilla, 12:20 AM 11/18/2002]
Old Nov 18, 2002 | 01:02 AM
HIGHRPM's Avatar
HIGHRPM
I don't think there is a 335/35/17 drag radial.
Old Nov 18, 2002 | 05:47 PM
gojo's Avatar
gojo
Default Re: Best offset? (HIGHRPM)
Your right, Thanks, This is the correct size.
315/35X17 Goodrich
Old Nov 18, 2002 | 06:24 PM
GaryZ06's Avatar
GaryZ06
I will be getting 17 x 11 ZR-1 style with the GS offset(50) It wiil stick out less the the ZR-1 offset(36)....My only problem is which 315/35/17 DR to go with....Nitto....BFG... :eek:
To Best offset?
