Harmonic Balancer Replacement That Turned Into a Full Engine Rebuild
Prior to pressure wash
After pressure wash
A few other components after pressure washing
Prior to a final clean and paint I decided to address the head mating surfaces. The proper way to preform this is with a CBN insert on a fly cutter, but as I don't have a great way to hold the block at the proper angle for machining i decided to use a technique that I've used countless times to rework components at work. Essentially, i used a sanding block to resurface the head mating surfaces. the key here is utilizing a large and extremely flat block. I'm using whats known as aluminum jig plate, its used in the machining world as base plates for fixtures and is certified as flat and parallel within 0.003 inches per foot. The piece you see here that i selected i found to be flat within about 0.0007 inches. I started with 220 grit and sanded while constantly changing patterns and direction until the surface completely cleaned. I then used 400 grit to achieve the desired surface finish. I'm pretty satisfied with the results, from what i can check its flat within 0.0018 which is well within the 0.003 factory spec. I'm in no way saying that this is better, or even equivalent, to the results an automotive machine shop could produce. But as this option was free in my case i figured i would give it a shot.
Jig plate used as sanding block
Head mating surface after the 220 grit sanding.
After the parts were dry, i used brake cleaner a wire brush and rags to prep surfaces to paint. Any part that need to sit in the clean state need to be preserved with something like WD40 or oil to prevent corrosion. I however was able to mask the components for paint immediately after the cleaning processes were complete. I used VHT engine primer (2 coats) and paint (3 coats) to coat the exterior of the engine components. Unfortunately, I forgot to take pictures durring the painting process, but the finished process can be seen below.
Block after paint
The last step in refurbishing the block is to hone the bores. This is really just to establish a crosshatch to aid in oil retention durring the break-in process of the new rings. I used a 4 inch 400 grit ball hone to quickly establish the desired finish. Make sure you use a lubricant while performing this process, it will help the hone from gathering debris and potentially scoring the cylinder walls. If you look closely at the pictures below you'll see the cross hatch in the cylinder walls. Yes, i will be inspecting the block dimensionally before reassembly to ensure bore sizes and flatnesses are within spec, but other than that the block is now ready for assembly.
Yes, I do work in aerospace. I work at a 2nd tier manufacturer as a continuous improvement lead, but have spent time in the tool room, as a process engineer and running a cell where i would fill in on burr benches, running machines, or applying coatings as necessary. It helps to work in manufacturing for a living to realize that any car is just a combinations of parts, if you understand their function and factory specifications it removes all of the guess work. Theres really no secrets or magic that lets any engine run, just provide proper quality parts with the right specifications in terms of fit and finish. I'm attempting to use this philosophy to understand were its possible to make concessions (like on refurbishing the block) and where its not (like the work being done to the crank that i'll discuss in a bit once i have all the info from the machine shop).
After separating the pistons from the rods the pistons needed some serious clean up . The carbon deposits were pretty substantial, as I expected based on the amount of oil in the intake. I started by addressing the carbon build up with some break clean and a wire brush. It took quite a bit of elbow grease to get the tops of the pistons cleaned. After that i used dish soap and hot water to clean the pistons, rods and wrist pins. everything made it over to the machine shop from evaluation and inspection before the holiday. Assuming there are no crack and everything's straight i'm going to stick with the stock pistons and rods. For my plans with the engine Im confident that they'll be up to the job. If anythings out of spec then i replace that component.
https://www.corvetteforum.com/forums...post1552993042
The LS engines are not externally balanced.
Much of this confusion is caused by:
1.Chevy zero balances the flywheel and pressure plates as a unit so the flywheel alone may not be zero balanced
2.Chevy refines the balance of Vette engines after they are assembled by pressing small weights into pre-drilled holes in the flywheel & damper as determined by spinning the engine as an assembly
3.Chevy did not refine the balance of Camaros so they will not have the small weights
4.New replacement dampers are zero balanced
5.Used dampers from a Vette may not be zero balanced if they still have the weights installed
6.Aftermarket flywheels are zero balanced
7.Aftermarket pressure plates are zero balanced
So here are a few chooses when modifying your engine
1.To change only the flywheel or only the pressure plate, match balance to the old value
2.To change the flywheel & pressure plate together:
•match balance an aftermarket flywheel/pressure plate as a unit
•when using a new Chevy flywheel/pressure plate, you can transfer the small weights or match balance
Other options include going back to a zero balance damper & flywheel/clutch by removing all of the weight or zero balancing everything, which is as good as a Camaro balance
Frame
Body panels
Drivetrain
The body panels all can be unbolted from the frame, which is how you get that "Vette-Kart" look. All of those can be removed independently of each other, including dropping the entire drivetrain in 1 piece. I did this when I did the LS3 swap a couple years ago. IMO it's honestly easier than pulling just the motor due to space, but then again I am using the lift in my garage. You basically support the front and rear subframes, unbolt everything, then pick the frame/body up off the ground.
The car went up on the lift and I started to tear it down. From a running, driving car to drivetrain out, it took me about 20 hours going slowly and labeling connections, taking notes about every disconnected wire, bolt, etc.
Rear tires are ready for a couple more months of use. These are Hankook Ventus V12s in a 285/35/19 and make for a great street tire. I even ran a few track days on them.
Exhaust components removed. Once I have the car up and running I'll be relocating the cutouts to the rear mufflers to do a "bypass mod on demand".
Finally:
Just some notes about dropping the drivetrain:
-It's easier to disconnect the rear diff, trans, and torque tube harness underneath the battery box and let them drop with the drivetrain than it is to leave them with the car.
-I left the EBCM/ABS module attached to the body (tied up with a string) but disconnected the brake line leading to the RF wheel so that I didn't have to remove the steering rack.
-If I was only doing the engine swap I would have probably pulled the engine alone, out the top. However, since I need to replace my whining 4.10s, I thought it would be easier to drop the whole assembly.
nsogiba, with the drive train laid flat on dollies like you have shown in the last post you made, about how high are the top of the heads? Just trying to get a rough idea how high i need to get the car?
