Oil cooler clearance problem
Old Mar 27, 2020 | 03:17 PM
unclebane's Avatar
unclebane
Default Oil cooler clearance problem
Hi guys!
I'm trying to install my new oil cooler but have some clearance issues. There is a sensor that blocks my AN-fittings. Anyone knows what sensors is in the picture below? Top left.
Dont mind the arrow, its the connection and sensor on top left I'm wondering about.
Old Mar 27, 2020 | 03:23 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Knock sensor, the LS 1&6's have them under the valley pan ???? maybe could move it to another spot ??? (to the block)
Old Mar 27, 2020 | 03:41 PM
unclebane's Avatar
unclebane
Thanks for your input! I've got a LS2 block, would that make it different? Forgot to mention that the picture is not mine.
Old Mar 27, 2020 | 04:11 PM
ImprovedRacing's Avatar
ImprovedRacing
Supporting Vendor
There should be another threaded bung a little higher up that you can move it to. In most cases you can angle the knock sensor a bit to clear the oil line fittings. However it looks like you're knock sensor may be a little different, hard to tell as I can't see the whole thing.
Old Mar 27, 2020 | 04:36 PM
unclebane's Avatar
unclebane
Thanks! I'll try to relocate the sensor. Got my oil cooler from Improved Racing for a C5, forgot I've got an LS2 block when I ordered...
Old Mar 27, 2020 | 04:57 PM
ImprovedRacing
Supporting Vendor
That will still be the best one to use, you just need to get that knock sensor moved or angled out of the way.
To Oil cooler clearance problem
