Code C1233 EBMC
Old Mar 30, 2020 | 10:55 AM
JLmiller's Avatar
JLmiller
Default Code C1233 EBMC
I know there is a lot of information on this topic. I have followed most of the advice I have found on the forum. I have a 2002 Z06 18,000 miles. I am getting C1233 code. After I clear the code it is come back on when I hit about 65mph. I can drive it for days and stay under 65 mph and the code never returns.
I have tried the following:
  • Switch the right and left wire harness that plug into the speed sensor, no change in code, also cleaned and check the connectors (male and female).
  • Tested the resistance and voltage of both front speed sensors, both seem to be in spec.
  • Cleaned grounds near the front fender wells.
  • While connected to my scanner monitored the wheel speeds they are always the same.
  • I ran jumper wires from the left side to the right side on both wheel speed sensors, drove the care still same code.
I suspect that I either have a problem in the wiring harness or a problem with the EBCM. The solder repair on the EBCM I have read about doesn’t seem to address this code.
Any thoughts?
Old Mar 30, 2020 | 11:25 AM
oelarse's Avatar
oelarse
The C1233 indicate RF wheelspeed sensor . Have you verified every connection point (C108 and C148 ) for good continuity including the EBCM terminals ?
Old Mar 30, 2020 | 11:46 AM
JLmiller's Avatar
JLmiller
Not yet. I will try
Old Apr 23, 2020 | 06:01 PM
JLmiller's Avatar
JLmiller
Default Update
I am still struggle with this. Today I noticed the code returned but I checked it before I turned the car off and it displayed a s a history code. My question is does the C1233 code ever appear as a current code or will it always be a h code?
Old Apr 24, 2020 | 02:53 AM
oelarse's Avatar
oelarse
My guess is that you have a temporary error (open circuit/short) appearing in a short period of time.
I you get a permanent short/open circuit then DTC 1233 should stay on Current permanent .
If someone could connect a scanner like Tech2 and monitor these speed signals and catch these signals when DTC 1233 appear you may get some more info .
Or you can replace wiring and RF speed sensor and see if it makes any difference
Old Apr 24, 2020 | 08:16 AM
JLmiller's Avatar
JLmiller
Thanks that is what I was thinking. I did use a Tech 2 monitor we could not see any change in the speed reported by the sensor. I am still thinking I have a wiring/connector problem but I cant seem to find and fix it. Very frustrating.
Old Apr 27, 2020 | 11:08 AM
JLmiller's Avatar
JLmiller
I did check the continuity, all good. The problem seems to be a quick short and them back to being ok. I think the problem is in the wires after the wire harness that plugs into the sensor or maybe at the connector at the EBMC. I am thinking about bypassing all of the wires in the harness all the way to the EBMC connector, I just hate to start cutting wires.
Old Apr 27, 2020 | 01:54 PM
oelarse's Avatar
oelarse
I agree to bypass the stock wires for this speedsensor seems to be the next step to try to solve the problem and solder the new wires in both ends .
If the alarm still pop up after this wire wiremodification a new speedsensor seems to needed
Old Apr 27, 2020 | 02:09 PM
JLmiller's Avatar
JLmiller
Thanks, I will try that sometime this week.
Old May 11, 2020 | 01:00 PM
JLmiller's Avatar
JLmiller
Tried to bypass wires same error. I spoke with ABfixer today they told me that I do have an problem with the EBMC but it cant be fixed. Where to buy a new or working used module?
Old May 12, 2020 | 09:56 PM
sloopdawg's Avatar
sloopdawg
could the wheel bearing be going?
Old May 13, 2020 | 08:55 AM
JLmiller's Avatar
JLmiller
Maybe but I put jumper wires from the left wheel to the right and right to left, got the same error. A wheel nearing would be a cheaper fix.
Old Dec 8, 2020 | 09:46 PM
JetBlack_Z06's Avatar
JetBlack_Z06
Navigator
Did you guys find a fix for this? I have the same constant code that appears even after clearing the code.
Old Dec 8, 2020 | 11:27 PM
Smoken1's Avatar
Smoken1
What all have you done to diagnose the problem? There are alot of threads on this problem
https://www.google.com/search?source...sclient=psy-ab
Old Dec 9, 2020 | 08:52 AM
JLmiller's Avatar
JLmiller
In my case I tried everything related to connection issues and nothing worked. I had to replace the EBMC. Easy job but had to pay $650 for the used part.
Old Dec 9, 2020 | 09:21 AM
bjones7131's Avatar
bjones7131
Did it fix your problem??
Old Dec 9, 2020 | 09:28 AM
JLmiller's Avatar
JLmiller
Yes no issues since I replaced it.
Old Dec 9, 2020 | 10:02 AM
JetBlack_Z06
Navigator
Idler pulley came loose which caused the belt to whip around, cutting the abs wire. I crimped the wire back on but the code still on. I already bought and changed that plug in wire that goes from the wheel hub sensor to the plug sitting on the frame. That didn't work. So, its either wheel sensor, ebcm or maybe the belt damaged another part of the wire i haven't seen yet.
Old Dec 9, 2020 | 10:58 AM
JLmiller's Avatar
JLmiller
I would continue to do all of the wire testing. It is not too hard to test the continuity for all the wires from the sensor to the EBMC.
I also created a jumper that ran between the left and right front wheel sensors. If you have a wire issue that should change the code.
To Code C1233 EBMC
