Cooling problems
Old Apr 22, 2020 | 11:05 PM
dfootdoc's Avatar
dfootdoc
Cruising
Default Cooling problems
I have a 2002 C5 ZO6 with a cammed 418 block and stock cylinder head that have been"worked to flow optimally".
. I have a larger radiator with integrated oil cooler plus additional oil cooler which is stacked up front right in the middle of the opened front fascia. The front end is the tiger shark. The car has 500 horsepower at the rear wheels and I race road circuits. The car still gets too hot at the track. Are there any Engineers out there to offer any advice. I'm curious if the stock cylinder heads aren't blowing enough air through the motor to keep things cool but really didn't want to get into bigger cylinder heads as possible. Car has plenty of horsepower already
Old Apr 23, 2020 | 07:53 AM
Fast one's Avatar
Fast one
Have you tried higher flow radiator fans?
Old Apr 23, 2020 | 10:32 AM
mmartinez's Avatar
mmartinez
I don't know much about the tiger shark front end, but some of those non stock front ends can decrease air flow thru the radiator. I would also seriously think about removing the additional oil cooler as it may be restricting air flow to the radiator, and does the car still have the middle air dam that directs air to the radiator, C5 were designed to pull in air from under the front bumper and direct it up onto the front of the radiator. Things to consider.
Old Apr 23, 2020 | 10:48 AM
GCG's Avatar
GCG
Originally Posted by dfootdoc
...The front end is the tiger shark... ...The car still gets too hot at the track...
Originally Posted by mmartinez
I don't know much about the tiger shark front end, but some of those non stock front ends can decrease air flow thru the radiator...
...does the car still have the middle air dam that directs air to the radiator, C5 were designed to pull in air from under the front bumper and direct it up onto the front of the radiator...
Take a look at this recent Thread with a similar situation. Problem was identified and solved.
Old Apr 23, 2020 | 11:29 AM
dfootdoc's Avatar
dfootdoc
Cruising
yes it has high flow fans, I already ran the car without the extra oil cooler up front...it got hot, that's why we added it and it DOES help, just how much it helps is not fully known since no races this year.
I do have the stock intake system bottom feeder with the stock lower air dam to push air to the intake and radiators. I know the stock system was very good and I never had heating issues with the stock motor even when I ran the car in summer with race tires for 15-20 min . time trials with NASA. BUT with the bigger motor I'm looking for engineering options in addition and to confirm to what the shop is saying and doing.
Old Apr 23, 2020 | 11:49 AM
mmartinez's Avatar
mmartinez
You may not have a large enough radiator to deal with the cooling requirments of that larger engine, just a thought.
Old Apr 23, 2020 | 03:28 PM
dfootdoc's Avatar
dfootdoc
Cruising
yes I mentioned that already. Again I've got an aftermarket racing radiator with oil intercooler (ron davis or dewitts...I forget which), PLUS an additional oil radiator up front.
Old Apr 23, 2020 | 03:33 PM
dfootdoc's Avatar
dfootdoc
Cruising
I should mention this is the Oil temp getting hot...not water temp.
Old Apr 23, 2020 | 04:06 PM
smitty2919's Avatar
smitty2919
1) Cylinder heads have no impact on "blowing air through the motor to keep it cool".
2) I'm confused...you have an aftermarket radiator with integrated oil cooler AND a external coil cooler? What are you using?
3) Not all oil coolers are created equal (staked plate vs fin and tube). Look up Improved Racing products for a solution and compare it to what you have.
4) Look in Autocross/Road Race section as this is a popular topic and discussed a lot for solutions. You don't have a "special case" or crazy build so a solution is already been figured out.
5) You could have added an oil cooler that is not sufficient (does not have a high enough BTU rating) AND with the addition of an aftermarket bumper it restricts proper air flow.
Old Apr 23, 2020 | 04:27 PM
Tokuzumi's Avatar
Tokuzumi
Move oil cooler inside of cabin, in front of AC vents. Run AC the whole time. Oil temps will be low.
All joking aside, are the lines from the radiator to the external oil cooler properly so oil is actually making it to the external oil cooler?
Old Apr 23, 2020 | 06:47 PM
mmartinez's Avatar
mmartinez
Have to be more specific on your post, I naturally assumed that you were talking about engine temp/water temps not oil temps, so either you do not have enough air flow thru your oil cooler or it doesn't have the ability to lower your oil temps sufficiently..
Old Apr 23, 2020 | 09:10 PM
slothman's Avatar
slothman
larger oil cooler with more fins.
Old Apr 23, 2020 | 10:51 PM
dfootdoc's Avatar
dfootdoc
Cruising
[QUOTE=Tokuzumi;1601380967]Move oil cooler inside of cabin, in front of AC vents. Run AC the whole time. Oil temps will be low.
All joking aside, are the lines from the radiator to the external oil cooler properly so oil is actually making it to the external oil cooler?[/
thanks guys, now I got things to check!
Old Apr 24, 2020 | 07:57 AM
ImprovedRacing's Avatar
ImprovedRacing
Supporting Vendor
Can you post some pics of your setup? What oil cooler and radiator do you have?
Upgrading fans only help improve cooling at idle or very low speeds, by the way. At track speeds the fan and radiator shroud is usually a restriction to air flow.
Old May 1, 2020 | 09:28 PM
dfootdoc's Avatar
dfootdoc
Cruising
will have to work on getting some pics and contact my builder for the details on products he used.
thanks everyone!
To Cooling problems
