Harmonic Balancer Install Woes
Old May 4, 2020 | 08:49 AM
feeder82's Avatar
feeder82
[/QUOTE]If using an ARP bolt, the specified torque value seems to vary, but when I replaced my balancer, with an ATI unit, and used an ARP bolt, the instructions from ARP called out 237 lb/ft of torque in one pass.[/QUOTE]
I have the same instructions, however ARP must have rounded off the recommended torque now the instructions per their website is 235ftlbs
Old May 4, 2020 | 08:50 AM
vettenuts's Avatar
vettenuts
If you think you bottomed the pulley with the installer, and the pulley doesn’t line up, I would remove and tie some basic measurements. It could be a hardware issue. I have also seen over time where a Camaro pulley was shipped by mistake, which results in misalignment.
Old May 4, 2020 | 09:14 AM
StingrayRebel's Avatar
StingrayRebel
