Harmonic Balancer Install Woes
Old Apr 30, 2020 | 09:22 PM
MultiVAC's Avatar
MultiVAC
Default Harmonic Balancer Install Woes
Hey all,
I'm putting my 5spd 02 C5Z back together after doing C5-R chain, chain dampner, oil pump, oil cooler, and AC work.
I've got an Innovator west standard diameter pulley I'm attempting to install. I can't seem to get it all the way seated. It appears to be half a belt rib from being all the way seated. I'm lubing the bore of the balancer and crank shaft.
I'm using an OEM brand balancer installer with a giant nut that presses through a bearing. In a few installation videos I've seen they don't seem to have too much trouble seating the balancer before switching to the final bolt and torquing that down. Now those videos featured a stock balancer, so I'm hoping that I'm simply dealing with tighter tolerances.
My current plan is to get a slightly better tool in the mail tomorrow - it should use all the threads in the crank. Then give it the beans on my torque wrench set to 250ft lbs.
Is there something I'm missing? I'm just trying to be careful not to blow the threads on the crank. If that doesn't work should I try boiling the HB in water?
Old Apr 30, 2020 | 10:18 PM
StingrayRebel's Avatar
StingrayRebel
it should go on fairly easy, how are you verifying that it is a half rib off?... without a laser tool it's hard to tell but you should feel considerable resistance in the tool when it is fully seated... did you happen to take a pic of the part number just to double check that the one you have isn't for a dry sump?
Old Apr 30, 2020 | 10:36 PM
MultiVAC's Avatar
MultiVAC
When I align the alternator and PS pulleys like sights on a rifle, the harmonic appears too be far forward.
I went and checked their website, the only thing odd is that I do have the blower hub... oh **** I might have the wrong crank seal on there as I'm using one from the gasket kit, not one from IW. Time to check!
Old Apr 30, 2020 | 10:46 PM
Fig_'s Avatar
Fig_
Try heating it up, when I did mine I stuck a heat gun on low in the hole on the balancer, and watched it for about 10 minutes right until it started smoking, I ran it to the car and installed it with no issue. I used a powerbond ud10%
Old Apr 30, 2020 | 10:59 PM
StingrayRebel
the blower hub does require a new seal, the inner diameter is slightly larger to accept the larger hub but I don't think that would keep it from fully seating... hmmm, try removing the balancer and take the seal out and then try to press the balancer back on and see what happens
Old May 1, 2020 | 02:22 AM
MultiVAC's Avatar
MultiVAC
Yeah I had the wrong seal for sure. I found the right on in the box and put it on. You're right though, it didn't make much of a difference as far as seating goes. I'm going to go for the heat gun method in the morning.
Old May 1, 2020 | 08:55 AM
Gordy M's Avatar
Gordy M
You can also try the oven method. Bake it at 200F for 30 minutes and with oven gloves slide it on and finish the install.
Old May 1, 2020 | 09:40 AM
StingrayRebel
you can give it a shot, I have installed a handful of innovators balancers and they have all gone on easily without having to heat them up and if his is going on all but a half rib I don't know if heat will make much of a difference... I would guess there is another issue like something with the oil pump or crank gear (if it was changed) that is keeping the hub from fully seating
Old May 1, 2020 | 11:17 AM
helga203's Avatar
helga203
Originally Posted by MultiVAC
Hey all,
wow 250 ftl bs that's what the instructions say?? I installed mine 15 yrs ago and the instructions were 140. I'm s/c'ed and had no problems. Stock ls1 dampens need to be that torque. But if it says it do it.
Old May 1, 2020 | 11:31 AM
feeder82's Avatar
feeder82
ARP balancer bolt requires that much torque 235ft lbs
Old May 1, 2020 | 01:51 PM
StingrayRebel
did your IW balancer come with a bolt?... mine did and it was around 140-150ft/lb I believe... if you bought the arp go with what it says but if you are using the bolt supplied by IW then check the instructions, the last thing you want is a snapped/stripped crank bolt
Old May 1, 2020 | 05:17 PM
helga203's Avatar
helga203
the bolt
Old May 1, 2020 | 05:21 PM
helga203's Avatar
helga203
I don't know if you were asking me the question but yes it came with the bolts in my kit with instructions that said 140
Old May 2, 2020 | 09:55 AM
MultiVAC's Avatar
MultiVAC
I figured 250 would be safe for the threads with the install tool (not the bolt) to pull on since stock and ARP are ~230. That's why I came up with that number. IW recommends 130ft lbs for the final bolt torque on the instructions I saw - which I may have upped to 150 in actuality.
The end result is that I tried everything, heating, more torque (didn't get to 250 though) and the balancer is in the same spot. I pulled off the IW and compared to stock and they dimension close to the same as I can measure, I think my eyeball method is flawed. I wasn't able to reinstall the stock one as I don't have the correct puller, but I believe it must have been sitting in the same spot.
Anyways, the car finishes going back together today - hopefully it turns out well.
Old May 2, 2020 | 10:33 AM
JWM's Avatar
JWM
This is the way to go. I heated mine to 170 degrees which is the lowest setting on my oven and had no difficulty whatsoever.
Old May 2, 2020 | 02:35 PM
MultiVAC's Avatar
MultiVAC
See I think I got it to around 250-300 with the heat gun for 20 mins. I'm fairly certain it must be all the way on. I guess I'll find out soon, just cleaning up now before I start her up.
Old May 2, 2020 | 03:12 PM
StingrayRebel
do you have a laser alignment tool?... that's a quick, easy, and accurate way to check
To Harmonic Balancer Install Woes
Old May 2, 2020 | 05:37 PM
helga203's Avatar
helga203
I remember when I installed mine on the nose of the crank was in about a 16th to 8th inch in. It was not flush with the pulley. If this helps.
Old May 2, 2020 | 05:38 PM
MultiVAC's Avatar
MultiVAC
I don't, but it looks like it was indeed fully seated. With the car all together the belt rides true. That tool is definitely going on the wishlist.
Old May 4, 2020 | 08:12 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Talk about confusion!!!!
The following is directly from the factory shop manual, and applies if you're using an OE, "torque to yield" bolt, to retain your replacement balancer.....
A) install balancer on hub;
B) install and tighten the used balancer bolt to 240lb.ft;
C) remove the used bolt;
D) install a new balancer bolt;
E) tighten the new bolt to 37 lb/ft, first pass;
F) tighten the bolt a second pass, 140 DEGREES of rotation
(NOT 140 lb/ft of torque!!) Emphasis is mine......
If using an ARP bolt, the specified torque value seems to vary, but when I replaced my balancer, with an ATI unit, and used an ARP bolt, the instructions from ARP called out 237 lb/ft of torque in one pass.
