PVC fix or whole new system?
Old May 11, 2020 | 02:27 PM
superfly85's Avatar
superfly85
7th Gear
Default PVC fix or whole new system?
I have a rip in the front of my pvc and was wondering is there a simple fix or do I need the whole system?
Old May 12, 2020 | 04:10 PM
Simtech's Avatar
Simtech
This thread may help.
https://www.corvetteforum.com/forums...old-elbow.html
Old May 12, 2020 | 07:05 PM
superfly85's Avatar
superfly85
7th Gear
Originally Posted by Simtech
That might just work Ill have to check.
Old May 13, 2020 | 12:12 PM
Billyjean9999's Avatar
Billyjean9999
i did this fix to mine as well. It does work. Ultimately I just used it as a temporary fix. I would replace the whole line. It’s only about $60-70 from rockauto can comes with new valve. Takes 10 minutes to install. A failed or failing pcv can cause a ton of different problems. Most likely caused me some oil leaks and cold start issues.
Old May 14, 2020 | 10:18 AM
superfly85's Avatar
superfly85
7th Gear
Wouldnt hapen to have a part number would ya? All the ones i found were way more expensive.
Old May 14, 2020 | 10:42 AM
feeder82's Avatar
feeder82
Ac delco 12590632 check it to see if it matches. The early vettes are different 97 98
To PVC fix or whole new system?
