Maintenance to do while intake is off?
Old May 13, 2020 | 11:43 PM
Agentlongwood's Avatar
Agentlongwood
Originally Posted by jim993
Rather than just replace the auxiliary air check valve, consider relocating it to a location where it is easily changed:
https://www.youtube.com/watch?v=vX1PqjlJk6A
So I noticed my car has the stock exhaust manifolds, but it looks like those air check things are blocked off with little plates, instead of a tube that connects to the manifold...
Old May 14, 2020 | 12:36 AM
Agentlongwood
Originally Posted by Samas
No problem. I just realized that guide uses the '01-'03 valley cover, rather than the '04. However, the key point is that the LS1 blocks need some grinding to make either of the new valley covers fit.
What is the difference between the '01-'03 and the '04 valley cover? Here I thought that all LS6 valley covers were the same. Does that mean I need to look for a 2004+ LS6 part specifically?
Old May 14, 2020 | 09:48 PM
C5tx's Avatar
C5tx
The '01-'03 LS6 valley cover uses an external PCV valve in the attached hose
The '04 LS6 and LS1 valley cover has a fixed orifice built into the hose fitting
Yes, I'd specifically look for the '04 version since it's the best. The part number that k24556 put in post #11 is the one you want.
HTH
