Intro
Old Jun 1, 2020 | 06:59 PM
4show's Avatar
4show
Default Intro
HI, I'm 67 now living in Orlando fl. New to corvettes but loved them since you think. Having problem with passenger side door electrics. Door lock, window and mirror stopped operating. Any help?? Change fuses, swapped module. Thanx vrrroom
Old Jun 1, 2020 | 07:33 PM
Vette_DD's Avatar
Vette_DD
Over 200,000 Corvettes built. How can we help you if we don't know what model and model year you're talking about?
Old Jun 1, 2020 | 08:43 PM
4show's Avatar
4show
sorry, 2000 C5 Z51 hatchback
Old Jun 1, 2020 | 08:52 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Jun 1, 2020 | 09:07 PM
Moved over to C5 Tech, but be prepared to post a bit more info on what the problem is with your car if asked. Good luck - hope you can get it solved.
Old Jun 1, 2020 | 09:17 PM
4show's Avatar
4show
thanx, I will be here again asking questions about this beautiful machine.
Old Jun 2, 2020 | 04:02 PM
4show's Avatar
4show
Still waiting for info to remedy this problem.
Old Jun 2, 2020 | 04:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You still have to got out your multimeter and start checking wiring !!..drivers door module is powered through fuses 33 and 34 (IPC fuse block)...see if you have power down to the module at both orange wires which should be "hot at all times"...pin 1 on the C1 connector and pin A on the C3 connector...you should also check the ground wire which is a black wire on the C2 connector...if you're not sure how to "properly" check the ground circuit give a holler !!...Hint: it's NOT a resistance check !!...glad to hear Disney is opening back up !!...will be retiring next month and shortly thereafter be living in SW Florida !!
Old Jun 2, 2020 | 04:51 PM
4show's Avatar
4show
thanx friend, I will need any and all the help you can give. Not a wires guy, more mechanical.
Old Jun 2, 2020 | 05:02 PM
C5 Diag's Avatar
C5 Diag
Don't worry about electrical...you are in the same boat as a lot of members here !!
To Intro
