QC code
Old Jul 7, 2020 | 11:16 AM
ALLEN007's Avatar
ALLEN007
Default QC code
My 97 just displayed "QC Code 123111". Can't find anything on that. Anyone know what that is?
Old Jul 7, 2020 | 01:15 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A “QC” code ??...never heard of that !!...can you take a picture ???...C5 DTC’s (codes) are either P,C,B, or U followed by 4 digits !!
Old Jul 7, 2020 | 01:28 PM
ALLEN007's Avatar
ALLEN007
Here's a pic. Did not notice it before, but right before the code came on the words "Quick Configure" for a second before the code.
Old Jul 7, 2020 | 01:35 PM
UM Rebel's Avatar
UM Rebel
Wow! Never heard of such a thing. Please post when you find out what it is.
Old Jul 7, 2020 | 01:37 PM
ALLEN007's Avatar
ALLEN007
So far doing a bit of research it's only on 97's. (from looking at older post about it) I might just see if I can reset the codes and see if it comes up again.
Old Jul 7, 2020 | 01:48 PM
ALLEN007's Avatar
ALLEN007
Below is a couple lines I found in an old post. I may try it. Don't guess it can hurt.
I'm going to reset all the options, seat, mirrors, alarm, etc and see if that helps.
Thanks for the help, I reset all the options I mentioned in the earlier post as the code popped up as soon as I backed out of the garage and immediately went to configure options. So I went through each one and reset them. Went for a ride and the strange QC Code 413131 never came back.
C5 Diag's Avatar
C5 Diag
This was a post by Paul Koener who is a C5 GM Tech on one of the other Corvette Forums....
“Hi there,
That is a configuration command used by engineering.
Do NOT continue, as this will mess up certain functions.
I personally messed up one car by trying to use this function and it was not pretty.“
Allthebest, c4c5
Old Jul 7, 2020 | 01:50 PM
ALLEN007's Avatar
ALLEN007
“Hi there,
Allthebest, c4c5
I did find that as well. But don't know how to get rid of it. Like I said above. I'll try that and see.
Old Jul 7, 2020 | 01:56 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I have not seen any tech info on this message, but apparently some of the 97 C5's can reach this function if the options button is held down for more than a few seconds when trying to get into the DIC settings.
Found this on the corvette action center forum.
"That is a configuration command used by engineering.
I personally messed up one car by trying to use this function and it was not pretty."
To QC code
