You have a loss of communication with your abs module . So making sure those abs harnesses are well plugged in and not damaged. Was the car fine before a wheel bearing change ?
No sir, since ive owned it, it has always had an abs/tc light with the tcs no comm. Its my track car so replacing the wheel bearings was just a prep item.
Hello, Skrimshaw! Thanks for sharing your -frustrating- experience with your ABS and EBCM. I have roughly the same problem (ABS Lights and TCS Lights and DIC warnings) but in my case, the ABS really doesn't work. In addition to No Comms with TCS, I have U1040 and C1571. I've checked and cleaned grounds and cleaned wheel sensors among other things to resolve this issue. I was thinking about buying a new EBCM (current one was fixed for the 1214 code by ABS Fixer a year ago) but I wasn't sure that would solve the problem. I appreciate the fact that you swapped in a good one from your other Vette to see if that worked. That indicated to me that I would likely not have any better results by replacing my EBCM.
I'm not sure how hard it is to replace the EBCM part of the wiring harness, but that thought has gone through my mind. If I understand correctly, you're seeing problems in that area.
I like to think that a Tech II in the hands of a clever technician would pinpoint the problem, but if the solution turns out to be an unobtainable replacement part, that's not a very satisfying result.
Good luck in finding a breakthrough!
Reason: clarification
im going to continue to plug away and figure it out. The car is outstanding on the track, im just grateful to be working on a platform that can stand up to track duty. With that being said, i have to figure this out!
I guess some don’t under stand open shorts or bad harnesses. Possible sensors , and or a module . Either way I would start with whatever is free 1st and move on to the next least expensive option if I’ve already concludes it is not a pcm or bcm .
I had a fuel theft deterrent code that numerous people for years never found the answer to . At the end of the day it’s because they lack code understanding . Understanding your code is key because they literally almost pin point the problem . Fuel theft deterrent =? A fuel door popper obviously. People were trying to lead me down a road here of lock cylinder bypass systems . Relearn sequences.ingition switches ect...everything but . So be careful on some advice on these threads .
I re checked the grounds and 12v and they were 100% in working order. This only left the serial wire in question. I cut back a piece of the coating on each end of the serial wire so i could "jump" a new wire from the ebcm connector all the way to the comb. Connected the wire, and started the car and sure enough, abs light is gone!
Of course, with the abs now functioning, it brought up a new list of issues:
c1281
c1282
c1284
c1287
c1288
These are all codes that came back after clearing it originally then driving it around for 15 minutes.
c1281
c1282
c1284
c1287
c1288
Find that hard to believe since you checked that circuit but the use of a scope would have been better to pinpoint this !!
I thought so too, i checked the resistance and voltage and got the same numbers except my resistance was like 180 instead of 150. I even double checked those readings on my other z06 and they were the same. Very odd, but sure enough its working now!
c1281
c1282
c1284
c1287
c1288
Forgive me for asking, but where is this comb of which you speak? Could it be the ground comb known as G101? Regardless, Your success with eliminating the ABS problem is giving me hope that I may someday be able to replicate it. A replacement or bypass harness seems to be more obtainable than other parts that could go bad (aftermarket manufacturers- are you listening?).
Thanks for your persistence.
