Power Window Problems
Old Jul 27, 2020 | 01:53 PM
97Chuck69's Avatar
97Chuck69
Default Power Window Problems
embly1997 c5 My drivers side power window will not go down. Everything in the window switch assembly works,,,, pass window goes up/down,, power door locks both sides lock/unlock, power mirrors both sides work, all lights come on. Driver side window is dead. Now by dead I mean there is nothing. When I push either the up/down button I hear a click, The click is at the module, Ear next module and hand on motor, nothing at motor just click at module.. This whole window mechanism was replaced about a year ago, motor and all and has worked flawlessly until yesterday. I do not know but to me everything points to module. HELP Chuck
Old Jul 27, 2020 | 07:36 PM
avigar's Avatar
avigar
Remove the door panel and tap on the motor housing a few times. It may just be frozen or locked. Otherwise...here you go. Does not require a wiring harness adapter. The regulators are pretty much disposable parts nowadays. Good luck.
https://www.amazon.com/gp/product/B079W9WRPT/ref=ox_sc_saved_title_5?smid=A31B1NF333K7B&psc=1 https://www.amazon.com/gp/product/B079W9WRPT/ref=ox_sc_saved_title_5?smid=A31B1NF333K7B&psc=1
Old Jul 28, 2020 | 07:54 AM
97Chuck69's Avatar
97Chuck69
As I said in my post I have replaced that about a year ago, but will try what you say.
Old Jul 28, 2020 | 08:02 AM
v6turbo87's Avatar
v6turbo87
Not sure what you put in for a replacement buy some of the aftermarket ones are junk and do not last.
Old Jul 28, 2020 | 10:56 AM
97Chuck69's Avatar
97Chuck69
Looked up my paper work and this is the exact one I bought back in Feb. 25, 2019
Old Jul 28, 2020 | 01:53 PM
FX VETTE's Avatar
FX VETTE
At $38 and some change I'm not so sure I'd trust that part not to fail soo quickly. Maybe try an OEM one this time and be done with it.
Old Jul 28, 2020 | 08:11 PM
Moved to C5 Tech.
Old Jul 29, 2020 | 07:14 AM
oktx's Avatar
oktx
No need to pull the panel. Make a fist and hit the inner door handle a few times fairly hard. This made mine work, for now. I will replace it soon.
To Power Window Problems
