Rhythmic vibration
Old Aug 2, 2020 | 02:22 PM
lunaticfringe007's Avatar
lunaticfringe007
Default Rhythmic vibration
My 02 Base Vert (76K Miles) has a rhythmic vibration that is most noticeable at about 75 MPH. It vibrates for a second and then stops for a second or two and then does it again. Its as if the road is uneven but it does not matter where in the road I am the vibration is the same. Sweeping turns left or right dont make a difference. I can feel it in the steering wheel and in the car in general. At lower speeds I dont notice it. I feel it less at speeds over 80 MPH but it is still there.
I have looked at other threads about this. Apparently it's a problem others have had and complained about. But I have yet to find a thread that found the solution.
I was thinking of replacing all suspension bushings or maybe wheel bearings but I dont want to just toss money at it. Any ideas?
Old Aug 2, 2020 | 03:03 PM
namvet6869's Avatar
namvet6869
Good luck. When you find answer let me know. I have done harmonic balancer, brakes, rotors and now new tires. Problem still there. This is a challenge and really don't know where to take it.
Old Aug 2, 2020 | 06:56 PM
redzg's Avatar
redzg
Not my vette, but on my Toyota pickup I had the same issue for far too long. Found myriad things wrong, including u-joints, and worn steering, wheel bearings. Pulled out what little hair I had left. Frustrated beyond belief, I went to my tire shop for one last balance check -- even though the vibration was rhythmic and random. They made me come out to see what they found on the spin balancer -- the treads on three out of the four tires were randomly ballooning out from the tire cases, retained by the edges of the tread rubber. Tires were about 8 years old, but with only 10K or so miles on them. New tires ended my year old frustration.
Old Aug 2, 2020 | 10:10 PM
jbbowtie's Avatar
jbbowtie
I had this same problem, turned out to be a front wheel bearing.
Old Aug 2, 2020 | 10:15 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Same problem in my C5 a couple years ago. The tires had not been balanced in quite a while so got them redone and the problem went away.
Old Aug 3, 2020 | 12:12 AM
Moved to C5 Tech.
Old Aug 3, 2020 | 09:19 AM
viffer's Avatar
viffer
Yup, same issue on mine and tire balance cured it.
Old Aug 3, 2020 | 10:27 AM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
Same here too! Just 2 weeks ago I experienced a similar vibration and had all 4 tires re-balanced. The shop said they were "off a little" and they did change the weight size and location on all 4 wheels and the vibration is now gone. My vibration was from 62-ish to 68-ish. Good luck!
To Rhythmic vibration
