'99 coupe engine repair question
Old Aug 10, 2020 | 04:56 PM
OregonDan's Avatar
OregonDan
Default '99 coupe engine repair question
Okay, guys. Can one pull the pan (both pieces) with the engine still in the car? Without raising the engine?
Part 2 - What's this I hear about some LS1s not having offsets in the pistons for the piston pin and others having an offset? Something about early/late and piston slap and etc.
Old Aug 10, 2020 | 10:25 PM
feeder82's Avatar
feeder82
The whole pan won't come out without dropping the cradle or raising the engine.
piston slap is pretty common on these motors, it's a piston to cylinder wall clearance issue. If it goes away after a slight warm up it's not a problem
Old Aug 11, 2020 | 09:35 AM
OregonDan's Avatar
OregonDan
Thank you. We think it's a wrist pin sizing issue, but whatever it is, it is annoying!!!
Are you aware of the offset issue?
Old Aug 11, 2020 | 09:46 AM
feeder82's Avatar
feeder82
That's a question for a professional engine builder. Offset pins are used in different situations like turbo charging, boring over standard, reducing piston slap
To '99 coupe engine repair question
