Easy ac belt replacement
Here in Arkansas im.not worried about the TB freezing up, so I did the tb bypass (I know it's not worth much, but just slowly getting my hands dirty). Anyway, a bit of coolant got on the ac belt and gave me that common bird under the hood sound. I figured I'd replace both belts with gatorback as I've read good things! The serpentine belt was perfect and fit flawlessly! The ACbelt on the other hand, I dont see how anyone could get this thing on!
I decided to do a bit of digging, and found out that the gatorback belt everyone reccomends (4040420) is actually 3/4" shorter than the factory belt. The gatorback belt goes in increments on 1/2", and the stock one is 42 3/4". I opted to go a quarter inch longer since I wanted ac and wouldn't mind a little chirping again lol.
I returned the 4040420 and swapped it for a 4040430 belt. This belt slipped right on the first try when I detensioned the tensioner, and has made a couple short drives with and without ac and makes no noise! Im.sorry if this is old news since I'm new here, but hopefully it helps at least one person!
