Am going to do the bypass. sometimes is a trick to get it to kick in.
My ? is, which wires does one tie together ? haven t taken the plug out so not sure how many is in there.
or jump a wire from what color to what color in the plug.
TIA Al
The switch in my C5 Z
It's a simple switch, only 2 wires. You can kinda see in the image you posted there are 2 prongs.
You can probably just unplug it, and with a sufficiently large diameter wire, stick one end of each wire into each prong on the mating connector.
TIA Al
Just cut the wires and tie them together. You cant miss up theres 2 wires; did this 18yrs ago.
