A/C vacuum problems Help
Old Aug 26, 2020 | 11:57 AM
Deliso1's Avatar
Deliso1
Default A/C vacuum problems Help
Hey guys, here’s the story and I hope someone can help.
I replaced my intake with an LS6 intake and while doing so we broke the little vaccum line behind the manifold. I ran a new fuel/vaccum line directly from the canister in the passenger fender well to the intake and buttoned it up. The problem is that the AC is blowing out of the proper vents but it is NOT as powerful as it used to be and very weak. I can’t figure out what the problem could be? Did I use wrong vacuum line?( It’s 3/16)
Definitely a real head scratcher and I could really use some help on this if anyone is familiar. 🤷🏻‍♂️🤷🏻‍♂️
Old Aug 26, 2020 | 12:08 PM
Theman5's Avatar
Theman5
Did you replace as it was before?
Old Aug 26, 2020 | 12:09 PM
Deliso1's Avatar
Deliso1
Yes I ran an entirely new line
Old Aug 26, 2020 | 12:30 PM
Theman5's Avatar
Theman5
same size too?
what is actual problem? Not as cold or air flow less? Does fan sound same ?
Old Aug 26, 2020 | 12:45 PM
Deliso1's Avatar
Deliso1
same size too?
air flow is less
fan sounds the same
Old Aug 26, 2020 | 01:50 PM
Theman5's Avatar
Theman5
I would double check engine bay connections to blower and stuff. Guessing intake changed with engine still installed
Old Aug 26, 2020 | 02:39 PM
Deliso1's Avatar
Deliso1
Yes it was
To A/C vacuum problems Help
