Started then just died.
Old Oct 4, 2020 | 11:01 PM
Twisted99's Avatar
Twisted99
Default Started then just died.
My 99 has mostly been sitting the past couple of years. but every time I've started it, no issues.
Today, when I need to get it out of our now old house, it started no problem, puller it out of garage, let it idle and 2 minutes later it just shut off.
Tried restarting, no fire. cranks over, just wont fire.
Usually i'd do my searches here first, but I'm in a HUGE bind. Need to move is ASAP, as house is going on the market next week
ANY help will be much appreciated
Old Oct 4, 2020 | 11:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Call me pm sent!
Old Oct 5, 2020 | 01:28 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Oct 5, 2020 | 06:53 PM
bonesbrakr's Avatar
bonesbrakr
Call a tow truck.
Old Oct 5, 2020 | 07:41 PM
C5 Diag's Avatar
C5 Diag
So have you narrowed this down to either a fuel delivery issue or maybe a crank sensor ??...if crank sensor you will have no spark and no injector pulse.
Old Oct 5, 2020 | 08:29 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I called him,,, He is very busy trying to move to sell his house. He stated that the fuel pump primed when he turned the key to ON. The battery was weak due to many attempts to start it and is on charge. Will know more tomorrow.
Old Oct 5, 2020 | 08:35 PM
C5 Diag's Avatar
C5 Diag
Thanks Bill for the update !!!...BTW I retired end of June, sold my house, bought a house in Southwest Florida and the closing is on Friday !!...LOVE it down here...a LOT of Corvettes around here !!
Old Oct 5, 2020 | 10:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Boy, HOUSE SELLING seems to be ramped. Im in the middle of getting my two houses ready to sell here in CT. Cant wait to get the FLOCK out of this state and move to El Paso TX. Already have a house there. Time to RETIRE (Jan) and head SOUTH WEST!!!!!! Bad part is I broke my leg and have to work around that PIA no weigh bearing issue on the left leg.
Old Oct 6, 2020 | 06:48 AM
C5 Diag's Avatar
C5 Diag
Its a sellers market right now so you should have NO problems selling both houses...I got 15K over asking price for mine and yes it’s time to get out of the Northeast. Sorry to hear about your leg and have a speedy recovery !!...if the OP has the pump priming we can “assume” it may be the CKP sensor but that still needs to be verified.
Old Oct 6, 2020 | 07:31 PM
Twisted99's Avatar
Twisted99
Sorry for not replying, I'm not getting emails that others were replying to the thread.
Followed Bill's first 2 steps.
pump is priming, and I'm getting fuel out of the Schrader valve.
Gas smells bad though.
I'm going to check spark tonight when I go to move more stuff.
Old Oct 7, 2020 | 12:01 AM
Twisted99's Avatar
Twisted99
Could not get plug wire off to check spark (no tools) but
attempted to start it again and it "fired" but stumbled and stalled.
Is it possible that bad gas is the problem?
Old Oct 7, 2020 | 10:27 AM
helga203's Avatar
helga203
Have to get a fuel psi gage on to see if psi drops
Old Oct 7, 2020 | 11:37 AM
mmartinez's Avatar
mmartinez
When was the last time that fresh gasoline was put in the the car, sounds like your car is having fuel delivery issues, I would recommend replacing the fuel filter.
Old Oct 7, 2020 | 06:55 PM
Twisted99's Avatar
Twisted99
probably 2 years ago
Old Oct 7, 2020 | 07:05 PM
bonesbrakr's Avatar
bonesbrakr
2 year old gas???
Old Oct 7, 2020 | 10:49 PM
Twisted99's Avatar
Twisted99
Originally Posted by bonesbrakr
2 year old gas???
yeah, I know.
I can't drive it due to other issues. And $$ has kept me from addressing those.
Old Oct 18, 2020 | 03:00 PM
Twisted99's Avatar
Twisted99
I want to say thanks to everyone who has offered their help.
And a BIG THANK YOU to Bill Curlee, for his knowledge and time walking me through troubleshooting.
We towed the car to the new house, and I'll get back at trying to fix it next weekend.
I don't think bad gas is the issue, started to drain the tank, and it did not smell bad, like the fuel coming out of the schrader valve did.
I'm going to get a fuel pressure gauge this week and check that.
The car will fire sometimes, but will only idle for a few seconds.
Again, thanks to all. This is the BEST forum, period.
To Started then just died.
Old Oct 19, 2020 | 01:19 AM
jim993's Avatar
jim993
Pull the codes. Clear them all and then try a restart and pull codes from that attempt.
Old Oct 19, 2020 | 12:17 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had him pull the DTCs several times. Directly after the engine starts and dies (without turning off the ignition) and ZERO DTCs pop. STRANGE.. I suspect that he is loosing fuel pressure after the initial prime but that can not be verified until he puts a fuel pressure gage on the fuel shrader.
I initially suspected that he had a bad ignition switch but he measured all of the BCM & PCM fuses in the ON/RUN position and he had good battery voltage on all the fuses. He also changed / swapped the horn and fuel relays around so, it most likely not a relay issue.
SO, we are waiting on a valid fuel pressure check to see if he looses pressure after crank and run.
Bill
Old Jan 9, 2021 | 10:18 PM
Twisted99's Avatar
Twisted99
FINALLY had some time last week to try and figure this out.
I bought a fuel pressure gauge (Harbor Freight). Shows ZERO PSI with key in "ON" or when cranking.
I can hear the pump prime.
I thought maybe bad gas, but after checking pressure several times, when I remove the gauge the gas looks clean and does not smell bad like it did when Bill Curlee had me see if fuel would come out at the schrader on the rail.
Definitely getting spark.
Changed the filter, still no start or pressure.
When I bleed off the fuel in the rail and try to start is when it fires for a second then dies.
