I have an 03 Z06 and I have killed 3 batteries in the last 3 days. This does not include the battery I replaced 4 months ago either. When I say kill, I don't mean they are drained dead and need to be charged. The cells in the battery go bad. 2 of the 3 batteries had a battery tender on them when they went bad ( 2 different tenders). Each time the battery dies I take it to Autozone, they give me a new one and 24 hours later it is toast. I understand a parasitic draw could drain the battery but what in they hell would ruin the battery?
History
I am 2nd owner and have had the car 4.5 years. It has 18,000 miles and is excellent condition. I have always had issues with batteries draining after the car sat for a couple weeks but never like this. I replaced the radio this summer but drove it for months with no battery issues. The battery I replaced earlier in the summer was before the radio install.
I just killed a 2 year old interstate battery, same bad cell diagnosis. Second one like that, but the other was a couple years older. I replaced my battery maintainer, not sure if that's the problem but over charging will kill a battery. I store my car every winter. Maybe just a run of junk batteries is to blame.
I tried a new battery tender on the last battery. It seems statistically improbable to get 2 bad batteries in a row, but I don't know at this point. I'm not even sure where to start with the problem solving.
Get a multimeter out and measure the charging voltage on the charger AND on the cars charging system - The typical charging voltage for a Lead Acid battery is between 2.15 volts per cell (12.9 volts for a 12V 6 cell battery) and 2.35 volts per cell (14.1 volts for a 12V 6 cell battery). These voltages are appropriate to apply to a fully charged battery without overcharging or damage.
If you have a Gel or AGM battery, Deep Cycle AGM:- AGM batteries should be charged using a charger with a mode switch for AGM type batteries. It is recommended to use a charger, current limited to 20% or 0.2C of the batteries capacity at a charging voltage of between 14.6 – 14.8V following deep cycle use, or 13.6V – 13.8V for standby use.
Your alternator should be charging anywhere between 13.5 - 14.5 VDC. Measure that voltage directly at the battery terminals with the engine running. I would test it under a daytime load and a night time load (lights ON, HVAC fan on high and rear defrost on. Se if the alternator regulator maintains the charging voltage.
