New balancer still wobbling
Old Oct 26, 2020 | 10:38 PM
Corvette186's Avatar
Corvette186
Default New balancer still wobbling
I replaced my oem balancer with a powerbond and an arp bolt. The old balancer had a slight wobble to it and was making the belt tensioner rattle at low rpm(<650).
Here’s the process I went through;
Pulled the old balancer with a 3 jaw from the inside of the balancer
heated the new one up in the oven at 250° for a few minutes
attempted to slide the balancer enough to get the original bolt to grab but it wasn’t on enough
used the new ARP bolt without the washer since it’s much longer that the oem to press it on far enough for the oem bolt to grab comfortably(this took very little torque) using a strap wrench to hold the balancer from turning over.
Torqued the old bolt to 240 as the manual states
Backed the old bolt out and installed the ARP bolt and washer following ARP’s instructions
My tensioner is still shaking quite a bit at idle, it’s hard to see the balancer wobble at idle speed but when I crank the engine under wot(so it doesn’t start) I can see the wobble clear as day. Also looking at the pulley after the power steering pump I can see the belt moving side to side.
I can also see them bolt it’s self wobbling as if the crank snout is bent. Anyone have any advice?
Old Oct 26, 2020 | 10:51 PM
Ed Ramberger's Avatar
Ed Ramberger
You never use the old bolt to try and pull a balancer on. You risk ruining the threads in the crank. You need to use an installation tool.
You also should not use a strap around the balancer because it stresses the rubber bonding material between the components abnormally and can damage the balancer. You should be able to tell if the inner hub is wobbling vs the outer ring at this point.
Your comment on the bolt wobbling is concerning. You may need to have this looked at by a qualified technician to assess the situation. It's hard to believe you pulled it on crooked, but I also can't believe you bent an ARP bolt. Are you certain the bolt is wobbling?
Old Oct 26, 2020 | 10:55 PM
Moved to C5 Tech.
Old Oct 27, 2020 | 12:00 AM
Vette5311's Avatar
Vette5311
AND you probably should have checked the crankshaft snout for runout with a dial indicator when the old damper came off.
Old Oct 27, 2020 | 12:01 AM
Corvette186
I know I should have used an installation tool but I felt comfortable with the amount of threads and the amount of torque I was applying. First with the arp bolt, I had multiple turns on it before torque began increasing. Then with the old bolt, I had around 4 full turns on it when I started and was monitoring the torque I was applying with the torque wrench. I was confident the threads would hold and the heat was helping which is why I didn't stop myself. Looking at my service manual, it does indicate that you use the old bolt after balance is in place to push it the rest of the way achieving the 2.40-4.48 mm distance to the crankshaft snout. Now with the belt wrench, I definitely agree that it isn't the ideal method but its an auto trans and I had to work with what I had. Ive seen other mention that they also used a belt wrench though hindsight says the flywheel lock would have been a lot easier.
Old Oct 27, 2020 | 12:04 AM
Corvette186
I measured the old balancer and seen some discrepancies. I assumed that was my issue, didn't think anything of the snout at the time. How do those even warp?
Old Oct 27, 2020 | 12:07 AM
Corvette186
Also I would like to mention that it runs smoother now than it did, and the tensioner does not make the noise that it use to.
Old Oct 27, 2020 | 12:10 AM
Vette5311's Avatar
Vette5311
Not warp but "bent crank" couple examples, as I'm sure there are others. Road damage, parking stops, car slipping off of jack under the cross member, etc.
Old Oct 27, 2020 | 09:11 AM
CinciZ06's Avatar
CinciZ06
The reality is, the elastomer ring in the two piece balancer is the weakest point of any part you touched during that job. It wasn’t designed to sustain the 240 ft lbs of torque that you applied while torquing the balancer bolt. I would bet someone else’s paycheck you separated the bond in the power bond when you did that. Now that you have to do it again get a flywheel locking tool if you have an automatic or put the rear wheels on the ground in 6th gear if you hand a manual and you will have no issues applying the 240 ft lbs.
Old Oct 27, 2020 | 09:46 AM
pjdbm's Avatar
pjdbm
You heated up the HB then you applied 240 FT pounds in a twisting movement, maybe that was an issue??
I bought the HB installer and the flywheel lock when I did this job.
No heat needed and it went on very easy and the flywheel lock went in without removing the exhaust or starter, just unbolt the starter and move it out of the way.
Old Oct 27, 2020 | 10:27 AM
helga203's Avatar
helga203
If u have to do it again which it sounds like you do. Don't go with a 2 piece dampner. Get a 1 piece. And then crank it down to arp spec. Then forget about it.
Old Oct 27, 2020 | 12:35 PM
MetalMan2's Avatar
MetalMan2
I agree with above, heated balancer plus strap wrench could have done it in. As CinciZ06 said, use the flywheel lock tool.
Old Oct 27, 2020 | 03:01 PM
Speedy007's Avatar
Speedy007
Crankshaft bearing or crankshaft is done best is to get right down greasy and to say the least dis assemble detach the torque tube and all the good stuff un hook all the engine stuff pull off whatever needs to be pulled off and remove engine dismantle that replace the crank ...
Old Oct 27, 2020 | 03:04 PM
Speedy007's Avatar
Speedy007
Yup Yup & Yup he twisted the crank input shaft with manual force ...Like he said u should have dropped it 6th with the wheels in the ground and 200 actually and even 180-190 was plenty I only ripped 180 about on my install cause of fear of twisting the crank with manual force of that 3/4 inch torque wrench with a breaker bar on that
Old Oct 27, 2020 | 03:14 PM
MetalMan2's Avatar
MetalMan2
What?
That's not what Cinci said... he said he thinks the balancer was compromised, he didn't say anything about crankshaft damage...
Old Oct 27, 2020 | 03:31 PM
Speedy007's Avatar
Speedy007
What he implies is possible but what I gathered from that statement it’s way more severe....But hopefully we will see the end results whatever the case may be
Use a summit puller and installing tool ...I have one works fantastic...ease of installing perfect...
Old Oct 27, 2020 | 04:35 PM
Corvette186
I’d like to update everyone here and say that the bolt it’s self is wobbling as well. So... I don’t really know where to go from here.
To New balancer still wobbling
Old Oct 27, 2020 | 04:37 PM
Vette5311's Avatar
Vette5311
Dial indicator runout will determine if crankshaft needs to come out.
Old Oct 27, 2020 | 04:40 PM
Ed Ramberger
Remove bolt and balancer and check crank snout for damage and runout. Check threads too. If all ok, properly install a new balancer. If not ok, take to qualified technician to assess repair. A video would be very helpful - pics might help.
Old Oct 27, 2020 | 04:41 PM
Corvette186
if it’s bent now, there’s no way that it wasn’t bent before. When it’s bent doesn’t the car run worse in any way? Might I add that the front crank seal was awfully leaky. Like I stated previously, the new balancer helped the vibrations some.
