00 c5, won't crank
The clutch safety switch was fine in my car. Replaced it with a new one as well as bench tested the original one and it was grounding properly.
The fuses 4, 50, and 52 are all in tact. Additionally, 50 and 52 are always recieving power as they should.
I attempted to check if the violet colored wire on the TDR was recieving power at cranking and this is when my multimeter broke so I have no answer to this. I decided to take the next step and jump the violet and red wire on the TDR with the key in the on position and the car started right up nad would continue running perfectly!
Does this definitely mean the TDR is my issue then? Just want to be sure before I order one and swap it out.
Also, figured I'd toss this foot well picture in here because it really seems like someone has messed with this wiring prior to me. The purple wiring hanging over the bcm just seems very not OEM-like. I know the red one running to the fuse box is for the aftermarket radio.
a. The YELLOW wire isnt providing 12VDC when you you position the key to crank
b. The BCM isnt happy with security and isnt GROUNDING the yellow black stripe wire ( just apply a ground wire to the yellow black wire and see if it cranks normally)
c The TDR Relay is bad and isnt energizing when it should. The last time I replaced mine, it was $12.
Try to switch these two relays is see if if makes any difference regarding starting the engine . If the engine starts fine you need a new relay
We have a winner here. Grounded out the yellow/black wire on the TDR and car is starting normally now.
Bill
Try to do a resistance check between A9:C1 and G104 .
